纺织机轴承搭建的数控雕刻机
Discussion in 'CNC Mills/Routers' started by mini li, Mar 21, 2016.
  1. mini li
    mini li New
    mini li published a new build:
  2. Joe Santarsiero
    Joe Santarsiero OB addict
    Very nice. Thank you for sharing.
  3. Ronald van Arkel
    Looks clean, I like the plates and bearings. Nice job on that one.
    -Ronald
  4. Mark Carew
    Looks very nice!
  5. Michael Shore
    Looks Nice, Your English (translated by Google) is much better than my Chinese, your Build looks good, I am interested in the bearings and wheels? can you tell us where you got them from?
    你的英語(由谷歌翻譯)比我的中國好得多,構建看起來不錯,我很感興趣,軸承和輪子?你能告訴我們你來自哪裡得到了他們?
  6. matt_o_70
    matt_o_70 New
    Ni hao - mini li.
    I am sure that there will be many people interested in the rollers and rails you have selected for this build - they look like nice parts for this application. I also like your solution for the belt mount and drive. This is a great way to use a larger belt for added strength.
  7. mini li
    mini li New
    轴承来着中国的淘宝。
    Bearing to Taobao in china.
  8. mini li
    mini li New
    Bearing Taobao from china.
    轴承来自中国的淘宝。
  9. JamesFoshil
    8mm光轴用啥型号的u型轴承?
  10. matt_o_70
    matt_o_70 New
    Thanks for the tip for SG20 bearing.
    It appears from the drawing that 8mm rods are (dw) for the SG20 to ride on. looking for economical 1500mm rods (or alternatives) at the moment. If your build is under 1000m this is not problem.
  11. Mr.Why
    Mr.Why New
    朋友,我在淘宝上找到了V型滑轮。
    Hi,My friend.I find the V-Bearing on taobao.com
    mini li likes this.
  12. mini li
    mini li New
    在淘宝搜索“轴承SG20”
    In Taobao search "轴承 SG20"
  13. mini li
    mini li New
    因为我需要用谷歌翻译,可翻译过来的意思我不一定能理解,请大家原谅。如果留言需要我回复请注明,如果我的回复你没有看懂可以再次留言。
    Because I need to use Google translate, can translate the meaning I don't have to understand, please yuanl
  14. Raymond Ho
    机器做得非常漂亮,羡慕中,大部分配件在淘宝上都能找到,我的也在设计中,打算用arduino做主控,请问你用哪款控制板?
  15. mini li
    mini li New
  16. ihu
    ihu New
    Late to the party, but this SG20 bearing solution is still looking good to me. Definitely will give it a try.
    两年后看到你的方案,我还是觉得很有启发。而且这个可能比直接用v-wheel更准更耐用,抽空会试一下。
  17. Bad Sequel
    Bad Sequel Well-Known
    Please take some photos of how the metal rods are attached to the v-slot extrusion.
    Looks to be a great way to avoid plastic wheels using v-slot. Also one can avoid using the shaft clamp used in the rawcnc machines.
