Zeus CNC Router Kit
Discussion in 'CNC Mills/Routers' started by snokid, Oct 13, 2014.
  1. snokid
    snokid Journeyman
    messing with the current and speed I got it sounding much better....
    the last thing I have to get right is the feed speed when cutting. getting close, y doesn't loose steps but x does when cutting 3/4" mdf with a 1/4" bit.
    Bob
  2. snokid
    snokid Journeyman
    Well I hope you all had a wonderful new years.
    I'm stoked, I got it 2" square with a 1" hole no lost steps!!!!
    I ended up with 1/32" multi-pass depth 30"/min feed and 70"/min plunge 1/4" 2 flute bit 3/4" mdf.
    This cnc stuff is a steep learning curve but if I can figure it out anyone can!!! LOL
    Dave Lowry, Nick W and GrayUK like this.
  3. Joe Santarsiero
    Joe Santarsiero OB addict
  4. snokid
    snokid Journeyman
    more video's for those interested
  5. cambo3d
    cambo3d New
    is the zeus machine all aluminum construction???. hard to tell in the pics and videos..
  6. snokid
    snokid Journeyman
    yes it is
  7. Dave Lowry
    Hi snokid, you still feel that it would be better to order your own parts? I am close to ordering a Zeus kit, or to start ordering my parts from openbuilds as they become available. I think the Sparks guy/guys are swamped. Takes a while to get answers from them. I worry that I will end up with a bunch of parts and not know what to do with them. Electronics that is. The mechanical stuff no problem.
    First thing I checked was the nema 23's, and they are out of stock. NOt a good start. I was planing on using that spread sheet someone here made as my BOM.
  8. snokid
    snokid Journeyman
    it depends if they aren't too backed up the kit is a good deal.
    all I had to buy was a router bit and a spoiler board.
    I did end up getting a 24v power supply but really not sure if it's totally necessary. I cut aluminum the other day and I was cutting at 10imp that's pretty slow.
    if you buy the parts when I checked it was less than a 100.00 difference. 1 order no mess no fuss.
  9. Dave Lowry
    Thanks snokid, looks like they are backed up a few weeks again. Hard for me to find nema 23's in stock.
  10. ChadRat6458
    I got the same board. Will you post a pic on how you mounted it? Did you put it in a plastic box with a fan or anything like that? Thanks.
  11. snokid
    snokid Journeyman
    No box, just a plexi glass plate I cut on the machine. No fans, but I did put heat sinks on the drivers.... I didn't have the heat sinks till just the other day though...
    I do like the cncxpro but I'm changing it out for a raspberry PI cnc board as soon as the one with 4 drivers is out...
    The only reason is I'm adding a PI board to my c-beam machine and want the same thing on both machines...
    I looked I don't have the sketchup file for the xpro anymore.
