Z-Touch Plate "Need Help"
Discussion in 'CAM' started by KEITHABEAR, Jan 3, 2019.
  1. KEITHABEAR
    I started using a touch plate for z height it was working fine but now the probe function still works like it should but after i jog cnc to unhook touch plate and return to zero the the z axes wants to go into spoil board. I am using universal g-code sender platform as soon as I input go to zero the tool icon goes off screen an takes a few seconds to come back down
  2. Ariel Yahni
    Ariel Yahni OpenBuilds Team
    If you are zeroing on OpenBuilds and then going into UGS then you need to zero there also as it does not know what you did previously S the procedure should be :
    Use the touch plate> remove it and zero on the OB CAM > Disconnect from the cam and connect to usg and once more make it zero that way it knows where it is before starting a job
    MaryD likes this.
  3. KEITHABEAR
    Thanks for the help
