z probe plate thickness setting for Interface Controller
Discussion in 'Interfaces' started by Rsgcncnube, Sep 16, 2021.
  1. Rsgcncnube
    I am using a custom Z probe plate and need to change the plate thickness setting in the Interface pendant. I can do it with the Control software on my laptop but not the pendant. The preset is .55 but not the thickness i need.
    I did the Flash drive wizard again in hopes the value would transfer but to no avail. Any insight on this would be great. Thanks
    Cannot find any other threads from you about this issue under this username? Tranferring supporting files is shown in the documentation: docs:interface:prepare-usb-drive [OpenBuilds Documentation] or what are you referring to?
    You can edit the Probing Macros on the flashdrive: OpenBuilds-CONTROL/PROBEZ.PRB at master · OpenBuilds/OpenBuilds-CONTROL to perform custom probing sequences, but for best plug-and-play support, get yourself an https://docs.openbuilds.com/xyzprobe
    Rsgcncnube likes this.
  3. Rsgcncnube
    My apologies, I was only stating what i tried. Not that we had conversed about it before. I appreciate your help. I usually reference all my questions from the search menu, As you or others have answered most basic questions before. However this one slipped my query. Thank you Peter!
    Ahh ok, thanks for clarifying, thought it was a seperate issue. :)
