Z hits homing switch at project start
Discussion in 'CNC Mills/Routers' started by BeeAMaker, Jul 21, 2023.
  1. BeeAMaker
    BeeAMaker Well-Known
    I am not understanding something here. Everything has been fine until today. Started the machine, homed all, secured my material, set X , Y, Z Hights. Load the project, hit start and the Z raises up and hits the home switch. It use to stop just before the home switch.
    I tried moving the switch up and down, I have tried setting my Z travel higher/lower. nothing seems to change. At the project start, my Z raises up and hits the home switch.
    The Z height is set according to what 2 points?
    Does it matter where the home switch is placed?
    The Bit raise at start is measured from what 2 points?
    EDIT:
    Never mind, I figured it out - somehow my Z got set to 0 in the post process.
    But would still like to know more of how to properly set the Z height if there is a guide I can look up.
    #1 BeeAMaker, Jul 21, 2023
  3. BeeAMaker
    Awsome, thanks
