Hi all, I just completed my build of a plasma table and am currently using Openbuilds in combination with Fusion. While the machine seems to probe fine about 60% of the time, it is intermittently getting the "probe complete" message before truly hitting the part. This then leads to incorrect cutting heights, ruining the part. I do not see the trigger in the diagnostic tab when this occurs. I am using shielded wire, so interference should not be an issue. I have attached a text file showing the probe satisfying at varying heights on a flat part. Any input is appreciated.
