Z Axis Limit Switch Mounting
Discussion in 'CNC Mills/Routers' started by SpringBob, Apr 4, 2019.
  1. SpringBob
    SpringBob New
    Could someone show me some examples of mounting limit switches for Z axis home/safety limit? Some pics or point me to a thread or two! Appreciate your help!
  2. sharmstr
    Sure, but what machine? It will be different depending on the type of z axis you have.
  3. SpringBob
    SpringBob New
    I have an OX. 2060 linear actuator.
  4. G-Wizard
    G-Wizard New
    @SpringBob - Attached is the Z-Axis Limit Switch mounting instructions I used for my Workbee. Whilst not the same machine as yours, it may provide some pictorial guidance of how the wires could be routed.
    For reference, it would have been a nightmare in my case to install the Z-Axis Limit Switch once the machine was full assembled. I read advice on this forum advising to install it much earlier in the build. Again, probably not much help to you at this stage.
  5. SpringBob
    SpringBob New
    Yes, very helpful! I have spotted a location for it and have devised a plan. Thank you for your kind response.
  6. G-Wizard
    G-Wizard New
    You're welcome @SpringBob. Glad it helped. Good luck...
    SpringBob likes this.
