Z Axis Height Difference
Discussion in 'CAM' started by Fintan Mitchell, Aug 12, 2022.
  1. Fintan Mitchell
    Hello,
    I've got a 3D adaptive clearing that should be taking out 4mm of material. Everything looks grand on the simulation but when the g code is generated the z axis height is up over 2mm from the stock top. Any ideas on why this is happening?
    Thanks,
    Fintan
    Must be something about the way you have set the heights....
    how big is the stock? (does Fusion have the same stock?)
    Where is your WCS offset in relation to the stock?
    Where is the part in relation to the stock?
