YAOR (Yet Another Openbuilds Router)
Discussion in 'CNC Mills/Routers' started by winand, May 30, 2014.
  1. winand
    winand Well-Known
  2. GrayUK
    I found this CNC Glass cutter on You Tube. Check it out.
    I've seen the cutter being made somewhere on the tube. They also make a cutter for cutting plastic. Trouble is I can't remember where.
    Gray
  3. RIDVAN ARIK
    Hi Gray,
    I see youtube.It is mirror cutting machine.I thing can make this machine.
    Thank you very much.I am serching this machine parts,project details e.t.c.
  4. GrayUK
    Can anyone remember the name of the CNC company that makes those rotating blade accessories?
    They use them for sign writing, and they also have another one with a roller for putting folds in DIY cardboard box construction? :rolleyes:
    I've seen them on YouTube, but I just can't remember their name. :banghead:
    Gray
  5. Tweakie
    Tweakie OpenBuilds Team
    Moderator
  6. GrayUK
    Yep. That's the one. I've put it in Resources for future reference.
    Ta.
  7. mytymedave
    Sorry if this was asked before but I did not see it in the thread.... Could you possibly share an approximate cost to build?
    Thx.... Dave
  8. Mark Carew
    I like how they have the stepper mounted like a spindle. Very cool machine idea thanks for sharing @GrayUK
  9. winand
    winand Well-Known
    Alright, now back on topic shall we? ;)
  10. GrayUK
    My apologies there Winand, I fell right into that one didn't I? Got sidetracked a bit.
    So, what you been up to? What you been making? Any probs?
    How is the Kress performing? Still a good decision?
    Gray
    P.S.
    For anyone else, reference, off topic!
    START A NEW THREAD! START A NEW THREAD!
    (Me Included)
    We like NEW threads!
  11. winand
    winand Well-Known
    At this moment, i have moved the machine to my (studio-)apartment to be able to use it a little more frequent. (yes i know, not ideal..)
    I seem to have some troubles which i want to work out.
    Mainly i've been cutting plywood from 6 to 12 mm thick, i experienced the following;
    - Cutter leaves burn marks on the wood and will evenually "burn" / ruin itself.
    I've tried to hold a power vac near the cutting area for cooling, that helps, but i need to slow down both the spindle speed as well as the XY speed a lot.
    - Gantry seems not rigid enough.
    After cutting some testpeaces of plywood on different feedrates (a simple straight line).
    I found that the faster the feedrate, the more of a "curve" it makes in the first part of the straight line.
    I'v "solved" that now cut down the feedrate drastically and more important, the cutting depth to only 2mm (with 4mm 2-flute)
    Cutting takes forever now..
    When twisting the gantry by hand, it feels very rigid, but there's a bit of flex when applying som edecent force.
    Difficult to tell what is flexing though, my guess is that the Openbuilds gantry plates are too thin and are bending a bit.
    I'm thinking of upgrading the machine a bit, hoping to cure this:
    - Using double gantry plates
    - Using double X-axis rail like on the OX
    Any tips are welcome..
    *Whisper* a 3d printer build is in preparation :)
  12. Tweakie
    Moderator
    Regarding the burn marks - as you have discovered, you either need to reduce the spindle speed or increase the feed-rate.
    Tweakie.
  13. winand
    winand Well-Known
    Indeed, i did both. I don't know what my feedrate is right now, but it's awfully slow. Kress (1050-1) on number 4..
    (and in this setting it works ok with a vac and a little patience..)
    Could turn both up, but then i run into accuracy problems, so that's my biggest concern right now.
  14. Tweakie
    Moderator
    I know exactly what you mean - it is really all a compromise. :)
    I often V-Carve hardwoods and getting the feed-rate high enough (to avoid the occasional burn marks) is a compromise against the strength of my machine.
    Tweakie.
  15. winand
    winand Well-Known
    While i'm planning to build my own 3d-printer now (already ordered all the parts), i also will upgrade my CNC router a bit.
    The biggest issue i have with it is (a little) flex of the gantry plate from left to right, and more flex due to the single 60x20 extrustion which is used for the x axis.
    I will:
    - Double the gantry plate and glue the two with epoxy to stiffen it up.
    - Add another X axis 60x20 extrusion which the gantry rides on (just like with the ox)
    Once this upgrade is done, pics will follow ofcourse ;-)
  16. GrayUK
    Hi Winand.
    You might consider putting two 20x20 lengths of v slot between the two 60x20s. Put one at the top, or near the top, and one at the bottom. Fix them all together, creating a very strong, and non flexing, X axis without a great increase in weight. You could sit your cable chain nicely in the slot at the top as well. :thumbsup:
    Of course this will mean some adjustments with the Gantry plates, maybe just some extra holes?
    But seeing as how you have a machine up and running you can always cut your own new modified parts out of Garolite to start with.
    Get it built and then make some nice aluminium plates. :thumbsup:
    There are plenty of plans available to adapt, or someone might even design the plate plans for you. :D
    Gray
  17. winand
    winand Well-Known
    Thanks Gray!
    I think adding extra extrusion in between will stiffen it up considerably,
    but for the current gantry plates it's too bulky. Maybe on a next upgrade :cool:
  18. slittle
    slittle New
    Now there's your vertical Murphy in action 3 wheels and all Nice Job Winand and I liked your rubber leg mounts. Also the supports you installed looks rock solid!
  19. winand
    winand Well-Known
    Finally i made an rigidity upgrade to my CNC machine.
    I found that it did flex a bit too much, the x axis beam was not rigid enough to my taste.
    I now have doubled this beam, so 40x60mm instead of 20x60mm.
    I glued two 20x60mm beams to eachother using 2 component epoxy resin.
    It was crucial that top and bottom were absolutely flush ofcourse(!)
    After that i extended the carriage and put 4 extra wheels.
    (excentric nuts now at bottom, moved them to top later for better accessability)
    I also doubled the Gantry plate which was flexing a bit when forcing the router up and down. (see picture above, right plate is double now)
    These to upgrades help a lot making everything stiffer.
    Hopefully i can route plywood a lot quicker or deeper now while keeping accuracy :)
    (and start trying milling some aluminium..)
    However, the flex i still notice seems to come from the wheels itself.
    Even one wheel bearing has too much play i found out.
    Guess replacing this bearing and upgrading the wheel to Xtreme solid wheels or even metal
    wheels could solve this.. next upgrade? ;-)
    Ronald van Arkel and GrayUK like this.
  20. dddman
    dddman Journeyman
    Starts to look like an OX! :)
  21. winand
    winand Well-Known
    Yes it does :D
  22. Ronald van Arkel
    Naa, it's an Routy Ox YAOR! :ROFL:
    But great, finally something less boring then and O X, keep the ideas coming! ;) To reinforce plates, use 20*20 or 20*40mm V-Slot (serves as cable guides as well).
    -Ronald
