Y2 Redlight
Discussion in 'Controller Boards' started by Fredrik Carlsson, Oct 4, 2021.
  1. Fredrik Carlsson
    Hey!
    I have done some cutting with my Openbuilds controller today. Suddenly when i go to jog the machine i notice only one Y motor is turning. I check the openbuilds controller and see that the red light is on over the Y2 motor.
    I turn off the blackbox controller in hope of the fault disappearing but it dosent. I try changing motors while the controller is off but nothing changes. I switch motors and cables but the fault comes in directly when i plug in the motor. Same if i change motors and cables.
    Tried letting it cool down, turn down voltage, checked powersupply.
    Everything sits in a garage wich is 12 degrees celsius.
    See docs:blackbox:currentadjustment [OpenBuilds Documentation] for a description of the causes that trigger the Fault monitor and turn on the LED
  3. Fredrik Carlsson
    Get in touch with the store via Support for further assistance
