Y limit light on
Discussion in 'Controller Boards' started by PaulN, Dec 28, 2019.
  1. PaulN
    PaulN New
    Hello
    just starting my workbee 1010 everything looks good however the status light on Y limit is on(red), when all others are off (green)
    "home all " Z and X homed but stopped there
    Any help on troubleshooting is appreciated
    Paul
  2. Christian James
    Christian James Journeyman
    I would start by unplugging the switch wires from the controller, then stick a (ohms) meter across the terminals of the switch and see what you get when its actuated. If its OK, then check at the ends of the wires (connector) while its still disconnected.. You must eliminate that before looking at the controller or something else
  3. PaulN
    PaulN New
    I will try that tomorrow, it acts like a nc contact.
    Suspect a bad switch
    Thanks for your input
    If you have a bad part, http://support.openbuilds.com/support/home will sort you out :)
    That said, its probably more likely wiring, switches aren't very likely to have issues out of the box (can fail after several thousand actuations but thats a couple years down the line)
  5. PaulN
    PaulN New
    Peter,
    thanks for the info, I'll be working on the build today and looking at the switch and wiring is on my list!
    I agree support has been very good in helping.
    I ran the motors briefly on Saturday seem to growl a lot not sure if this is normal.
    There is a sine-wave running through the coils, so a gentle hum is normal, growl, sounds like a tiger on the loose :)
    Make a recording of the noise and I'll be happy to have a listen and tell you if its normal though
  7. PaulN
    PaulN New
    okay
    Checked wire harness no issues
    Checked switch open and closed no change
    Removed x limit and put in place of y limit status light went to off, when activated got hard limit triggered
  8. PaulN
    PaulN New
    everything came up nice this morning no growl hope to cut later today
