Y axis problem
Discussion in 'General Talk' started by Yanis, Jan 20, 2021.
  1. Yanis
    Yanis New
    Hi. My name is Yanis and I am new to cnc. I have workbee 1500 x 1500 with Blackbox, I bought it from SPAM , initially it had NOVUSUN controller set up with Drufel soft.I did cut one sign, but then it started to give me errors, x axis limit reached or xyz axis limit reached. I decided to change controller to a Openbuilds Blackbox, because I read good reviews, and wanted grbl anyway. I kind of got it running, but y axis is stalling now, wich never happened with NOVUSUN . There are no warnings or "!" lights on. Some times I can jog it back and forth no problem, and then it starts to stall one of the y axis motors. Usually it stalls and when I jog it again it goes 15cm or so and stalls again.I attached small video. I Hope somebody can give me some advice. Thanks
  2. Gary Caruso
    Did you try increasing the current with the current adjust pots?
    Set it to about 75%, also if one motor is always the one cutting out then it's probably a wire issue.
    Gary
    Check Grbl settings > Dial back Acceleration, the BM motors are high inductance, doesn't accelerate very well
  4. Yanis
    Yanis New
    Thanks for sugestion, but they are sitting on 75%, when tried to increase got red "!".Tomorrow will try to swap y and y2 motor plugs to see if the same motor stalls.
  5. Yanis
    Yanis New
    Thanks.I did not think about that. Will try that as well, they are high torque nema23 steppers, what should be good Acceleration?
    Expirement with the values. No one will be able to give you a number as no two setups are exactly the same
  7. Yanis
    Yanis New
    Thanks for your advice, it looks like acceleration adjustment helped. Had to turn it down a lot. Did 5 hello world jobs no problem during that, but after first two jobs Controller soft crushed, lost connection with Blackbox. After restart everything good again. After last 3 jobs no problem. Actually motor stalled once during a jog, between the jobs, after that I reduced maximum jog speed, it seems like everything is good now. Will play more next week. Would you have any sugestions for ofline Gcode generators? My workshop is in a bad area, very week Network
    Yanis
  9. Yanis
    Yanis New
