Y axis proble
Discussion in 'OpenBuilds Forum Help' started by RogerThat, Aug 27, 2023.
  1. RogerThat
    RogerThat New
    Dear all,
    I have an issue with my CNC with BlackBox controller. CNC is quenbe ULTRA 1000 x 1000 with 2,2 kW spindle.
    In Fusion I created 25 x 25mm calibration part with 2x 4mm holes.
    I calibrated X, Y with help of caliper. When I send G90 X150, machines goes to X 150,0xmm. Same for Y axis.
    Problem starts when I cut this square. X axis on the spot 25mm, Y axis is 25,2mm. For 2 holes there that I am using Bore function. Holes are oval and have 4mm only when I am measuring distance between 7 o'clock & 1 o'clock. The rest of inner diameter varies from 3,6mm in X and 3.8mm in Y.
    As tool I am using 2mm single flute, I measured it and actual diameter of flute it is 2.25mm. So this I also updated in Fusion.
    In Fusion I imported new OpenBuild post process v1.0.36.
    I have checked all screws on the machine.
    Now I am clue less what to do next.
    Do you have any idea what can cause this issue?
    Thank you for any suggestion.
    Both GCodes are in attachment.
    GCode for square:
    (Made in : Autodesk CAM Post Processor)
    (G-Code optimized for default controller)
    (OpenBuilds CNC : GRBL/BlackBox)
    (Post-Processor : OpenbuildsFusion360PostGrbl.cps V1.0.36)
    (Units = mm)
    (Arcs are limited to the XY plane: if you want vertical arcs then)
    (edit allowedCircularPlanes in the CPS file)
    (Drawing name : cutting v30)
    (Program Name : 1_calib_square_25mm)
    (1 Operation :)
    (1 : 2D Contour15)
    ( Tool 1: Flat End Mill 1 Flutes, Diam = 2.25mm, Len = 6.00mm)
    ( Spindle : RPM = 12000)
    ( Machining time : 22 sec)
    G90 G94 G17
    G21
    (When using Fusion 360 for Personal Use, the feedrate of)
    (rapid moves is reduced to match the feedrate of cutting)
    (moves, which can increase machining time. Unrestricted rapid)
    (moves are available with a Fusion 360 Subscription.)
    (Operation 1 of 1 : 2D Contour15)
    G54
    (This relies on homing, see Search Results for Query: G53 fusion | OpenBuilds )
    G53 G0 Z-10
    G0 X42.725 Y28.2
    M3 S12000
    G4 P1.8
    G0 X42.725 Y28.2 Z15 F1000
    Z5
    G1 Z-1.575 F120
    Y28.208 Z-1.633 F1000
    Y28.23 Z-1.688
    Y28.266 Z-1.734
    Y28.312 Z-1.77
    Y28.367 Z-1.792
    Y28.425 Z-1.8
    Y28.65
    X42.717 Y28.708
    X42.695 Y28.763
    X42.659 Y28.809
    X42.613 Y28.845
    X42.558 Y28.867
    X42.5 Y28.875
    X28.875
    Y56.125
    X56.125
    Y28.875
    X42.5
    X42.442 Y28.867
    X42.388 Y28.845
    X42.341 Y28.809
    X42.305 Y28.762
    X42.283 Y28.708
    X42.275 Y28.65
    Y28.425
    Y28.367 Z-1.792
    Y28.312 Z-1.77
    Y28.266 Z-1.734
    Y28.23 Z-1.688
    Y28.208 Z-1.633
    Y28.2 Z-1.575
    G0 Z5
    G1 X42.725
    Z-3.075 F120
    Y28.208 Z-3.133 F1000
    Y28.23 Z-3.188
    Y28.266 Z-3.234
    Y28.312 Z-3.27
    Y28.367 Z-3.292
    Y28.425 Z-3.3
    Y28.65
    X42.717 Y28.708
    X42.695 Y28.763
    X42.659 Y28.809
    X42.613 Y28.845
    X42.558 Y28.867
    X42.5 Y28.875
    X28.875
    Y56.125
    X56.125
    Y28.875
    X42.5
    X42.442 Y28.867
    X42.388 Y28.845
    X42.341 Y28.809
    X42.305 Y28.762
    X42.283 Y28.708
    X42.275 Y28.65
    Y28.425
    Y28.367 Z-3.292
    Y28.312 Z-3.27
    Y28.266 Z-3.234
    Y28.23 Z-3.188
    Y28.208 Z-3.133
    Y28.2 Z-3.075
    G0 Z15
    G53 G0 Z-10
    M5
    G0 X-10 Y-10
    M30
