y axis operating at different speeds
Discussion in 'Motors' started by Nate Byl, Jan 15, 2021.
Thread Status:
Not open for further replies.
  1. Nate Byl
    Nate Byl New
    I have recently finished the construction of a Openbuilds lead 1515 cnc and everything seemed to work perfectly until I uploaded the lead 1515 profile in open builds control. At which point y-axis motor 1 started to move at 1/2 to 1/4 of the speed of y-axis motor 2. This sends the whole gantry out of square and just about breaks the corner joints. I have checked all the wiring and it all seems to be good. When I restore the machine to the original setting all axes also seem to work fine, Just very slow jog speed. Please let me know some possible solutions to this problem.
    Would indeed be wiring. Y1 and Y2 are not independent from Grbl settings point of view. The step and dir signals are parallelled to both drivers.
  3. Nate Byl
    Nate Byl New
    Hi peter,
    Thank you for you fast response, I ran new wire to the motor, and redid all the connections, and still the same issue. Is there any other possibilities of what the problem could be?
    Disconnect the motors from the machine, put them on a desk, flag some tape around the shaft so you can watch them move: Then do some testing to see if the issue is related to Mechanical (i,e binding when its on the machine) or electronical (still acts funny even when machine is removed from equation)
  5. David the swarfer
    This tells me that the LEad1515 settings are too fast for your mechanicals, which means that the Y side that lags behind is too tight. disconnect both motors and turn the screws by hand and compare the feel.
  6. William Campbell
    I had the same issue, check the motor wire on the one that's lagging and make sure all the wires are on top of the clamp in the connecter and not under it as mine was.
    Giarc likes this.
Thread Status:
