Y axis direction intermittent
Discussion in 'General Talk' started by John Raney, May 28, 2022.
  1. John Raney
    Hi
    my y1 is stable but y2 is intermittent in direction but step may be consistent. It is hard to tell. I have checked connections. They seem ok. Could this be a symptom of a broken stepper motor.
    Also I put in a new Interface, the BB is 2.7. It seems that all the jumpers are in the correct place for new Interface. The old and new Interface exhibit the same problem. Could I have messed up something in the BB?
    your help is appreciated
    john raney
  2. Alex Chambers
    I know you said you checked the connections, but that really is a typical symptom of one poor connection out of the four . Check that you haven't clamped onto the insulation instead of the bare wire.
  3. John Raney
    Thanks I will look again that seems to be the most probable.
  4. John Raney
    Thanks that was the problem
    Alex Chambers likes this.
  5. Ian Rusch
    Ian Rusch New
    Yes
    had the same problem found a solder joint under some heat shrink on the back of a plug faulty
    Thanks for the help as usual
