Y and A motors turn opposite.
Discussion in 'General Talk' started by Jondrea Smith, Jun 25, 2019.
Tags:
  1. Jondrea Smith
    I'm having trouble with my Y and A axes. I have Y and A slaved together, according to the Blackbox instructions. The slave axis jumpers are set according to the Blackbox documentation, but the motors turn opposite one another. Is there a setting inside Openbuilds Control, or do I need to change a grbl setting? Any help would be greatly appreciated.
  2. Giarc
    If it is a belt machine, you want them to spin opposite. If lead screw, then just reverse one wire pair on one of the Y motors.
    Jondrea Smith and sharmstr like this.
  3. Jondrea Smith
    Thanks for the reply. I am running leadscrews on my Y axis. So I just need to reverse one coil's polarity? I'll try this today.
  4. Giarc
    Reversing one pair for the Y should do it.
  5. JCCD
    JCCD New
    I'm having this same problem. Which pair to switch? Blue & green? and should they be switched both at the motor and at the controller, or just at the motor?
