XYZ Touch Probe Plus
Discussion in 'Helpful Tools' started by Joe9663, Nov 11, 2023.
  1. Joe9663
    Joe9663 New
    How well does this work with a vbit like the Amana bits?
  2. Alex Chambers
    It doesn't - you can use it to probe Z, but you can't probe X & Y with a V bit.
    I don't use a bit at all to probe X & Y, I use a brass rod of known diameter then change to the bit to probe Z.
  3. Joe9663
    Joe9663 New
    Thanks for the information. I didn't figure it worked with vbits, but thought I should investigate before trying. I don't want to mess any of my bits or the touch plate up
  4. Joe9663
    Joe9663 New
    Do you know if I can flip the plate over and probe the bottom for z? That way I can probe the center of the project instead of the edge?
  5. Alex Chambers
    Yes you can.
