XYZ Touch Probe Plus
Discussion in 'General Talk' started by cdalyai, Jun 24, 2020.
  1. Peter Van Der Walt
    Measure your machines actual working distances (travel from one end of each axis to the other) - or if its one of our standard machines, just load the relevant profile from Grbl Settings:
  2. Keith Parker
    Thank you, Peter. I thought it was only used if enabled soft limits so I stayed away from that. So now I can continue with my initial problem. Love you guys OpenBuilds Rocks
    Alex Chambers likes this.
  3. cnc0014
    cnc0014 New
    When I try to set my origin off of the back right of the material via the advanced settings it probes in the X+ and Y+ directions (i.e. off the touch plate). How do I get it so it recognizes the plate/probe orientation correctly?
    FYI, I do have the X axis inverted in the GRBL settings because I put my motor on the left side of the gantry but I would think the settings on the probe would take that into account.
