Xyz Probe
Discussion in 'Controller Boards' started by AndyCase, Aug 7, 2020.
  1. AndyCase
    AndyCase New
    Hi all
    Sorry if this isn't the correct place, but I'm using the 1010 with Blackbox controller.
    Someone has given me a XYZ probe for free.
    BUT it only has 2 wires. One goes to the clip for attaching to the tool, the other should go to the controller.
    Can it work with the Blackbox or do I need to have 3 wires?
    You can use it just fine
    Just set it up as a custom probe
    NB make sure of wiring! SIG and GND only! Do not wire V+ as you can cause shorts then
    AndyCase likes this.
  3. AndyCase
    AndyCase New
    The clip should be GRD and the other wire SIG?
  5. AndyCase
    AndyCase New
    Custom can do XYZ. But not the fully auto mode that also determines the endmill diameter that the official probe can do. You have to measure and enter the endmill diameter manually
    Of course the probe has to be an XYZ type then with the offset side overhangs
  7. AndyCase
    AndyCase New
    Ok thats great. Mine looks exactly like the official one, but just 2 wire. I have quickly tried the Z, but ran out of time to use it properly.
  8. AndyCase
    AndyCase New
    OK I've got the probe and wired it.
    I've set up the Offsets under Custom Probe.
    I've measured the distance between the edge of the probe and the edge of the hole. Photo attached.
    When probing it does it but then sets the home about 10mm too far forward and to the side.
    Am I measuring the offsets correctly?
  9. Peter Van Der Walt
    Oh and your calipers are on the hole edges, but i can see the offset is thicker at the edge with the screw hole... Measure the offset from 0,0,0 to probes edges and top surface
  11. AndyCase
    AndyCase New
    Is it the thickness of the sides that rest up against the X and y of the piece rather than the hole edges? Those are about 15mm thick
  12. Peter Van Der Walt
    Yes that's correct. Hole has nothing to do with it
  13. Fed
    Fed New
    Is there anything you can do if you accidentally connected the v+ with GND?
  14. Peter Van Der Walt
    Sometimes that kills the board, very often not. Disconnect all wiring, test again. Then if it is dead http://support.openbuilds.com/support/home will be happy to help you buy just a replacement Brains board (cheaper than the whole kit)
    Fed likes this.
