XYZ movment error
Discussion in 'CNC Mills/Routers' started by Antony Lidorginakis, Nov 25, 2020.
  1. Antony Lidorginakis
    why this gcode lines is giving me an error at startup ? and how can be resolved?
    (Profile 1)
    (Tools used in this file: )
    (2 = End Mill {0.5 inch})
    N100G00G20G17G90G40G49G80
    N110G70G91.1
    N120T2M06
    N130 (End Mill {0.5 inch})
    N140G00G43Z2.0000H2
    N150S12000M03
    N160(Toolpath:- Profile 1)
    N170()
    N180G94
    N190X0.0000Y0.0000F250.0
    N200G00X0.1432Y16.6013Z2.0000
    N210G1Z-3.0297F200.0
    N220G1X0.1401Y16.3156Z-2.8691F250.0
    N230G1X0.1378Y16.1014Z-2.7544
    N240G1X-0.2013Y16.1011Z-2.7542
    N250G1X-0.3073Y16.0981Z-2.7543
    N260G1X-0.4306Y16.0902Z-2.7543
    N270G1X-0.4482Y16.0890Z-2.7448
    You need Grbl compatible GCode - what CAM are you using? The Gcode above contains invalid commands like G70, that is not supported by Grbl: See about halfway down on the Grbl Wiki
    We have Grbl Post processor files for Fusion, Vectric, etc
    You just need to use a Grbl post for your CAM, if it does support the option, otherwise, find a CAM that has support for Grbl: See docs:software:overview [OpenBuilds Documentation]
  3. Antony Lidorginakis
    Thank you very much!!
    How can i make the Z to go up 5cm while is cutting a straight line
