Xtension Limit switches, please help
Discussion in 'Other Builds' started by DavidCNC2017, Feb 22, 2021.
  1. DavidCNC2017
    Hi
    Recently I bought Openbuilds Xtension Limit switches to install them on my GRBL machine. Machine is based on Arduino ( to be more exactly to the Phoenix GRBL controller, which is one of incarnation of Arduino boards).
    I would like to get some help.
    First of all, as I am reading in internet , all sources recommend to use normally closed switches in CNC machines, saying that in that case there is a little bit more safety.
    I can make the Xtension Limit switche as NC, but seems I will loose the noise reduction in that case.
    Can anybody help me with the wiring diagram of Openbuilds Xtension Limit switches to regular Adruino board ( not Black box !)
    Thank You in advance
    David
    SIG to the signal pin
    GND to GND
    V+ to 5V
    No need, Xtension limits have onboard RC filters, and the Grbl default settings work with NO switches
  3. DavidCNC2017
    Thank You !
