XLarge C-Beam Gantry Plate Sandwich.
Discussion in 'Other Builds' started by ReneX, Jul 2, 2023.
  1. ReneX
    ReneX New
    Hello,
    This has already been asked before but the links on that post are broken and I could use some more clarification so I will ask again. I would like to be able to sandwich two XLarge C-Beam Gantry Plates together as shown in the picture below:
    Could someone please provide the parts and instructions to achieve this? So far what I think is needed to accomplish this is the following:
    1. Take one XLarge C-Beam Gantry Plates.
    2. Insert four Low Profile Screws M5 65mm long into the plate and turn it around.
    3. Insert four 6 mm Aluminum Spacers (one on each bolt).
    4. Insert four Precision Shim - 10x5x1mm (one on each bolt).
    5. Insert four Xtreme Solid V Wheels (one on each bolt).
    6. Insert four 9 mm Aluminum Spacers (one on each bolt).
    7. Insert four Xtreme Solid V Wheels (one on each bolt).
    8. Insert four Precision Shim - 10x5x1mm (one on each bolt).
    9. Insert four 6 mm Aluminum Spacers (one on each bolt).
    10. Take another XLarge C-Beam Gantry Plates and create the sandwich.
    11. Insert four Slot Washers - 15x5x2mm (one on each bolt).
    12. Tighten everything up with four Nylon Insert Hex Locknut (one on each bolt).
    Please let me know if the instructions listed above are correct.
