X32 Connection Issue (Moved thread)
Discussion in 'Controller Boards' started by Dustin Bouma, Jun 27, 2024.
Thread Status:
Not open for further replies.
  1. Dustin Bouma
    I dont know where to go man my controller wont connect and when I try and connect it to different ports cause the controller cant be connected. how can I get a new controller
    BlackBox 4X or X32?
  3. Dustin Bouma
    X32
    Then not related to the thread you posted in (4X specific issue).
    Moving your posts to a new thread
    For X32 connection issues, see the documentation's comprehensive FAQ instead. docs:blackbox-x32:faq-usb-connection-failed [OpenBuilds Documentation]
    In future, please open your own thread for your own issues unless directly related to an existing thread thanks, just helps keep the forum well organised to help you best.
  5. Dustin Bouma
    yea I have done all of that. Also the black box doesnt fire up unless it is plugged into the computer dont know if it is supposed to fire up with just the power source. It is throwing a controller not responding code
    It is, so lets check that first for you. Can you post pictures of how you have the PSU wired to the BlackBox (both ends) and pictures of the PSU if its not our usual
  7. Dustin Bouma
    here is the pics of the black box and what the screen show when i try to connect different ports
    Thanks, but its missing the power supply side pictures also requested
  9. Dustin Bouma
    I think that side has nothing on it. Does the wiring look right?
    We'd be happy to check everything for you - just best. Thanks
    The more info you provide the less back-and-forth the quicker we can get you sorted.
    Please do post pictures of the Power Supply wiring for review
    Awaiting all the info requested to continue
  11. Dustin Bouma
    Got it
      File size:
      76.4 KB
      File size:
      76.4 KB
      File size:
      74.4 KB
  12. Dustin Bouma
    sorry takes just a little time to run back and forth to get pictures
  13. Peter Van Der Walt
    That is still not the pictures of the power supply :) - those three are just three more different angles of the BlackBox X32.
    You already mentioned you had the power supply wired up:
    If it was wired incorrectly, or its a bad PSU, best to disclose so we can see if theres a way forward.
    Feels a bit like you are avoiding posting the pictures, after three requests so far. Was there an accidental miswire?
  14. Dustin Bouma
    Here are the pictures of the power supply. i am not avoiding posting any pictures at all. This machine not running is costing me about $400 a day. I went with you guys to see if your machine is as advertised since then I have had missing parts with my table buy and CNC buy. Not to sound like "that Guy" your wiring system is fairly simple and I get it really not a chance I could wire it wrong. It has never fired up unless plugged into my computer. I followed all the instructions on the youtube video multiple videos actually. I can keep going if you would like? I dont have the money or time to sit here and have you tell me i am holding back. I will send you any picture you would like I just miss understood you and I have to walk to my shop to get them. sorry to inconvenience you. thank you for your time
      File size:
      98.4 KB
      File size:
      52.6 KB
      File size:
      69 KB
      File size:
      74.1 KB
  15. Dustin Bouma
    Does the wiring look incorrect?
  16. Dustin Bouma
    one video that I watched the fan turns on super high as soon as it fires up mine doest do that
  17. Peter Van Der Walt
    So on the BlackBox you have GND as white (incorrect)
    But on the PSU you have correctly got Black on GND.
    Reverse polarity wiring sadly would have been the cause of death. See the IMPORTANT WARNING sections of the Documentation: docs:blackbox-x32:connect-psu [OpenBuilds Documentation]
    As mentioned in the FAQ's Section 6.3.1 some incorrect wiring can cause permanent damage
    Sorry about assuming you were withholding. By the third request (along with the symptoms and the reply denying that it would be related) it felt best to ask. Imagine our perspective from the above conversation as well.
    Sadly this BlackBox is destroyed.
    Unfortunately the warranty does mention exclusions
    See OpenBuilds Warranty
  18. Dustin Bouma
    perfect so how do I get a new one
  19. Peter Van Der Walt
    Checkout BlackBox Motion Control System X32
    Triple check all wiring against BlackBox Documentation before powering on anything to avoid future damage.
  20. Dustin Bouma
    say what you want man I have had problems with this whole Machine. It should be covered under warranty because of all the bullshit I have to go through to try and build this **** thing
  21. Dustin Bouma
    The black box doesnt come with any documentation
  22. Dustin Bouma
    You guy reference a YouTube video for everything and a forum so if a person that is doing the video is wrong my warranty is void? Ill watch the video again and if he doesnt say anything about which wire goes where than what?
  23. Peter Van Der Walt
    I am closing the thread in line with our Terms of Service , any further communication can be referred to Support thanks.
    Re-check the box it came in, on the inside of the lid (as you open it you can't miss it, right next to where the BlackBox lies) - normal link as well as a QR code to docs.openbuilds.com/blackbox
    On the products themselves you'll also find the polarity printed for convenience.
Thread Status:
