X-Y travel speed not following gcode
Discussion in 'CNC Projects' started by Chris611, Dec 17, 2022.
  1. Chris611
    Chris611 New
    My x and y speeds on my plasma table are not following the gcode. I cut a 60mm diameter circle and it takes 27 seconds. That is about 500 mm/min. The g-code has F2000 for speed. Attached are the g-code and settings.
    Nema 23 stepper motors. Black Box 4x.
    Any help would be appreciated.
  2. sharmstr
    Are you using OB Control? If so, double check your feed rate slider.
    The max feed rate settings look fine, but since its a bunch of small moves, it may have to do with acceleration. Someone smarter than me will know.
    Also noticed that your steps per mm for each axis is set to 250. Its a sign that you probably havent calibrated your machine.
  3. Chris611
    Chris611 New
    Ok. Calibrated the steps per mm. It was the arc issue; I drew a rectangle in Openbuilds and it was must faster. I downloaded Sketchup Maker 2017 and Sketchup CAM. I'm struggling to figure out how to setup my z axis touch off with the switch from openbuilds. The g-code I use in openbuilds is below. I'm not sure what settings to change in sketchup CAM
    G38.2 Z-30 F100; Probe
    G10 L20 Z-2; Set Z Zero
  4. Chris611
    Chris611 New
    Also I currently use M3 to fire the plasma, the SketchUp cam has M5. How do I change that?
    Acceleration is set quite low too:
    $120=10.000 ; X-axis acceleration, mm/sec^2
    $121=10.000 ; Y-axis acceleration, mm/sec^2
    $122=10.000 ; Z-axis acceleration, mm/sec^2
    Have a read through github.com/gnea/grbl/wiki at some point.
  6. David the swarfer
    SketchUcam has a laser mode but not a plasma mode. To get plasma touchoffs you will have to do some searchandreplace in the gcode file.
    I don't understand what you mean by having M5?
    M3 is 'spindle on'
    M5 is 'spindle off'
    in 'GRBL power mode' M4 is spindle on (read the GRBL wiki to learn how power mode works with acccleration., you DO NOT want this with plasma)
    On the hole featureoptions menu you want to turn power mode and feedrate in arcs off (false).
    Also make sure you set the spinde RPM in the parameters dialog to the correct value for 'fully on', depend son your GRBL settings for max spindle speed
    Sketchup Menu Tools|Phlatboyz|Options|Hole Feature Options
    do read the help, the plunge hole dwell time is also used for laser output. (big blue question mark in the toolbar)
    Here is my quick sample in laser mode with the above settings, I drew 3 rectangles and outside cut them, nothing fancy.
    Code:
    (Generated by SketchUcam V1.5c-fc1fbff)
    (Bit diameter: 1.0mm)
    (Feed rate: 750.0mm/min)
    (Plunge Feed rate: 450.0mm/min)
    (Material Thickness: 6.0mm)
    (Material length: 780.0mm X width: 450.0mm)
    (Overhead Gantry: false =    Climb Cut)
    (Plunge Depth first)
    (Optimization is ON)
    (Arc Feedrate scale is OFF)
    (LASER is ON)
    (www.PhlatBoyz.com)
    G90 G21 G49 G17 F450
    G00 X30.978 Y35.435
    M05 ; ensure laser off
    M03 S12000  ; laser on, 12000 is my max rpm set in GRBL setting $30
    G01 Y82.635 F750
    G01 X78.178
    G01 Y35.435
    G01 X30.978
    M05  ; laser off
    G00 X83.51 Y68.564 ; move to next rectangle
    G01 Y112.164 F750
    G01 X177.71
    G01 Y68.564
    G01 X83.51
    M05 ; off
    G00 X97.335 Y51.346 ;move
    G01 X177.735 F750
    G01 Y18.846
    G01 X97.335
    G01 Y51.346
    M05
    (home at end of job)
    M05
    G00 X0.0 Y0.0
    M05
    M30
    to convert this to plasma code you will need to search for the M3 lines and replace with your touchoff code and then the M3 line again, thus inserting the touchoff code before all the M3 lines.
