X axis not homing.
Discussion in 'Control Software' started by Jacob123, Aug 26, 2019.
  1. Jacob123
    Jacob123 New
    Yesterday I went to set up my workbee for a cut. I tried to home the machine. The z axis homed normally, but when the x and y homed it seemed that the x didn't move independently. It moves just a hair towards the limit switch then backs off when the y axis hits the switch.
    It seems like it thinks it hit the limit switch. The switch works. The switch seems to be fine.
    Any ideas?
    Most likely EMI causing a false trigger early in the homing cycle: couple options
    -space limit wiring far from mains/motor/router wiring
    - upgrade to Xtension Limit Switches (built in EMI filtering
    - upgrade to a BlackBox (built in EMI filtering)
    - wire in a 0.1uf Cap and 10k pullup for each limit (no need with Xtension Limit Switches or BlackBox)
    - add ferrite filters to limit switch wiring
    #2 Peter Van Der Walt, Aug 26, 2019
  3. Jacob123
    Jacob123 New
    Thanks Peter! I'll give that a try when I get back in the shop.
