Has anyone reported issues with the new CONTROL update? I use it with my X-Carve and the x travel distance has doubled. I checked the $100 and it is correct. The 3D preview is correct, but the cut is stretched on the X-axis.
I’m having a similar issue seems after the last update last night I did but my measurements along the x axis are by about 1/2” I tried the calibration wizard according to the wizard it’s right on the money 3D viewer shows the correct measurements but if I click the check size tab up top the machine is still shorter then it should be how do I calibrate the micro steps as stated in
