Wrong Pocket Size Results
Discussion in 'Other Software' started by blue25, Jul 21, 2018.
  1. blue25
    blue25 New
    Hi,
    Recently I have build my first CNC based on Sphinx.
    For the controller I use Gecko G540. CAD software use Aspire, and MACH3 to run the G-Code
    I have strange result for my pocket operation.
    When I make pocket toolpath frrom aspire, for example i make 20mm pocket, the result is 19mm. When I try to make 10mm pocket, the result is 9mm. Any size I want to make, the result is 1mm smaller in X and Y.
    But when I make profile toolpath, the result is right. 20mm profile, will cut 20mm. Also for other size.
    Need a lot of advice here.
    Regards,
  2. JustinTime
    JustinTime Veteran
    I'm not familiar with Aspire but I can tell you that the problem is with Aspire. It is possible that you have a setting that makes it smaller, like maybe it's only the rough cut and it expect a final, finish cut, which is many times 0.5mm (which is 1mm in total).
  3. blue25
    blue25 New
    hi, for cutting (profile toolpath), it has no problem. the size is right. but when doing pocket toolpath, it have the problem. and aspire doesn't use rough cut & finish cut except for 3d object. for 2d pocket toolpath, it doesn't use rough cut & finish cut
    here is the gcode from the aspire
    T1M6
    G17
    G0Z20.000
    G0X0.000Y0.000S7730M3
    G0X9.148Y9.057Z5.000
    G1Z-2.000F600.0
    G1X12.638F1200.0
    Y12.547
    X9.148
    Y9.057
    G1X6.608Y6.517
    G1X15.178
    Y15.087
    X6.608
    Y6.517
    G1X4.068Y3.977
    G1X17.718
    Y17.627
    X4.068
    Y3.977
    G0Z5.000
    G0Z20.000
    G0X0.000Y0.000
    M30
