Workbee with arduino nano
Discussion in 'Interfaces' started by KTLighting, Nov 1, 2019.
  1. KTLighting
    Hi all!
    I need urgently help on this. I've setup a workbee with an arduino nano but i can't upload the grbl library. I have 4 nema step motors and drivers, a 24V power supply and a nano shield board wirh arduino nano on it. I have dowloaded the grbl library from grbl/grbl and tried to upload it to the nano through arduino ide.
    Any ideas??? Thank you very much.
    #1 KTLighting, Nov 1, 2019
    Did you follow the install instructions on the Grbl Wiki?
    Of course making sure you selected Nano in boards menu instead of uno (it uses a different bootloader)
    Genuine nano or chinese fake - if fake, make sure you have the ch340 drivers installed and auto reset might not work so play with the reset button (let go just when IDE says "uploading"). Or get a real Nano that works better than the fakes
  3. Giarc
    Did you download the Arduino IDE so you have all the drivers?
  4. sharmstr
    All the genuine drivers..
    If it's a fake, check what USB chip it uses, usually CH340, sometimes Prolific or CP2102. Those are not included in the Arduino IDE install
