WorkBee upgrades Overview
Discussion in 'General Talk' started by Blake Barr, Dec 11, 2019.
  1. Blake Barr
    Upgrades involve the following:
    Chris Laidlaw spindle mount
    TBD CNC linear Z
    DIY linear X using reinforced C beam and X mounting plates flipped
    I am able to achieve some pretty incredible results in aluminum and I've even started dabbling in mild steel.
    here is the latest part i machined on my router. On this particular piece, i was running .125" DOC and .040" step at 150IPM and it was a little to much. In the first video, it ran .0625" DOC and .025" step at 150IPM much cleaner. I think .080" DOC is gonna be about the limit for that much feed but I'm gonna be playing around with feed rates and cutting depths to see which saves the most time and offers the best finish.
    Giarc, Rick 2.0 and sharmstr like this.
  2. mcfly7777
    mcfly7777 New
    That is awesome, thanks for sharing. Can you share the CAD views for the machine particularly the z axis?
  3. Waste
    Waste New
    very nice .
    As linear rails are expensive compared to wheels etc, would changing only the Z axis give you more accuracy and less play than the X ??
    and also what kind of feed rates do you use for mild steel and aluminum??
  4. Giarc
    He has them listed in the videos. And now I want to go out and try some mild steel. I need to find some scrap for testing.
