WorkBee - Table size
Discussion in 'CNC Mills/Routers' started by Benjamin Vg, May 9, 2019.
Tags:
  1. Benjamin Vg
    Benjamin Vg Well-Known
    Hello,
    I have finally buy a full Workbee kit but the biggest one 1,5m x 1,5m on ooznest.
    So now the I need to find a solution to store it in my garage :)
    I have a very stable and robust table but the dimensions are 1,8m x 1m so I would like to know if i need to add something like a torsion box to extend my table or if the structure of the Workbee is ridgid enough to exeed of 25cm on the left and right?
    Also I woul like to know if the leveling of the table is something very important because currently my table is mounted on balls and I would like to keep it but of course my ground is not 100% leveled.
    Regards,
    Benjamin
  2. Alex Chambers
    Hi @Benjamin Vg, the flatter and stiffer the base for your workbee the better. 25cm is a lot to hang over the edge of your table - a torsion box would be ideal, but I think you need to extend your table top somehow. I haven't built a torsion box for my workbee yet (I will one day :D) - it's on a plywood base stiffened by battens. I don't think level is as important as flat, but if your table has one or more legs unsupported then there will be a lot of vibration (and noise) - vibration is not good with bits of your machine possibly working loose.
  3. Benjamin Vg
    Ok thank a lot (again) ! :)
  4. Colin Mccourt
    Colin Mccourt Journeyman
    I just made a new table top to fit over existing work bench and strengthened with heavy duty L brackets then bolted everything through to sub table...very sturdy see my build for details you may be able to glean or improvise on something from that
    Regards
    C
  5. Benjamin Vg
    Thank you but I didn't find the build you are speaking about...
    Regards,
  6. Alex Chambers
    Colin is referring to the build called "The Bee and Me"
  7. Benjamin Vg
    ah ok thank you!
  8. Colin Mccourt
    Here is a sample pic of my machine. I had an old workbench laid around so I fashioned a new (wider) top for it from MDF and stud wall timbers. In hindsight, I should have used ¾ Plywood. for the fact that MDF is subject to moisture and can swell. This doesn't really affect me as yet as the stuff I make doesn't call for critical tolerances. but I just thought I'd mention that point.
    Regards
    C
  9. Benjamin Vg
    Thx I had finally found your post. Due to the size of the machine 1m50 x 1m50 and the available size of the mdf and plywood. I am doing it (in progress) in MDF in place of plywood because I had to buy 4 panels and it become a bit too much.
    I store some mdf since a long time in my garage and never had any moisture yet so I hope that is will stay like this.
    Thanks for the advices!
    REgards,
