Workbee position disable
Discussion in 'OpenBuilds Forum Help' started by Romain Wood, Aug 21, 2021.
  1. Romain Wood
    Hello everyone
    I have mounted a 1010 workbee with a blackbox
    the motors move in the right direction and the limit switch functions.
    I can not get the numeric values in the open builds software of the machine position, it always remains "Disable"
    here are the screenshots
    I specify that I use a nema 213 motor from stepperonline reference: Nema 23 Bipolar 1.8deg 1.9Nm (269oz.in) 3A 3.36V 57x57x76mm 4 Wires ref 23HS30-3004S
    the cable connection is as follows
    engine / Blackbox
    Black (A +) / Red (A +)
    Green (A -) / Blue (A-)
    Red (B +) / Green (B +)
    Blue (B -) / Yellow (B-)
    has anyone ever had the problem?
    What could I have forgotten?
    Thank you for your help
    Troubleshooting tab > application diagnostics > untick Disable DRO
    You've accidentally disabled the DROs - that menu is for disabling features on slow PCs
  3. Romain Wood
    indeed this "option" is checked thank you for your answer and especially the speed
