Mark tried several times to paste Serial Console and the Grbl settings file hopefully you can read them.
Thanks for the settings, but what exactly is the issue? False Hard Limit triggers? If yes, refer to docs:blackbox:faq-emi [OpenBuilds Documentation]
I sent another set out under WorkBee 1510 Y hard limit 2 with more detailed info think I sent it to wrong area don't see it under your area. Peter, I attached several images the last one is the image pulled into control giving the g-code operation serial console reading etc. Hopefully you can see the problem and advise me how to rectify it. Home settings work fine, its when I select run job the Y axis goes toward the switch till it hits causing the hard limit error; at the same time Z axis comes down toward the zero setting, X axis goes toward the switch......if I move Y axis away from it hitting the switch...X axis switch is hit. All axis have zero settings. I have ran this same drawing several times with no problems till this last upgrade and lost the Grbl setting to the WorkBee 1510. I just don't see the error in the code to be able to fix the problem. Not and expert on the code settings trying to learn as I go. I have yet to actually cut parts out the drawings have to be precise so its back an forth til I achieve the size. I have several drawings made but holding up on cutting out the parts for assembly. Attached Files: a" style="margin: 0px; padding: 10px 10px 0px; overflow: hidden; zoom: 1; background: none center top repeat-x rgb(255, 255, 255); border-radius: 5px;"> upload_2020-8-23_16-55-33.png File size: 151.4 KB Views: 1 upload_2020-8-23_16-56-49.png File size: 232.8 KB Views: 1 upload_2020-8-23_17-1-3.png File size: 222.6 KB Views: 1 upload_2020-8-23_17-2-14.png File size: 150.9 KB Views: 1 upload_2020-8-23_17-2-54.png File size: 161.3 KB Views: 1 upload_2020-8-23_17-3-45.png File size: 164.9 KB Views: 1 upload_2020-8-23_17-4-13.png File size: 159.9 KB Views: 1 edited-gcode.gcode File size: 88.1 KB Views: 1 Bobbolink, Yesterday at 7:50 PM
Something went a little wrong with your reply, the images arent accesible. But CONTROL can't wipe your settings. Only you (clicking save on Grbl settings tab with either invalid settings in there, or clicking one of the EEPROM reset buttons), or an EEPROM (hardware on the controller) can cause that Homing does not ZERO the job, so make sure you jogged to the correct origin (and make sure your CAM job is setup to have the origin relative to the stock where you are setting it) and did do SETZERO CNCs are by nature accurate, so not sure why you are doing that. - Calibrate the machine - CAM up with the correct endmill diameters and other dimensions - Run JOB = accurate
