Workbee 1510 Lead Screw Upgrade Help!
Discussion in 'CNC Mills/Routers' started by Dave Hossler-Lamp, Sep 19, 2020.
  1. Dave Hossler-Lamp
    Hey guys! I currently have a belt driven WorkBee 1510 with the high torque Nema 23s. I would like to upgrade to lead screws for improved accuracy. I’m going to post pics of what I have in my cart currently. Please let me know what else I need to make this conversion smoothly.
  3. Dave Hossler-Lamp
    Hi Peter,
    I emailed Openbuilds approximately 2 weeks ago and haven't received a response.
    Check your spam folder first. Or refer to the now released Tension Actuator (new product)
  5. Dave Hossler-Lamp
    THANK YOU PETER!
    Good call on the Spam Folder. I never think that stuff is going to go there when I've received emails before... It was there!
    Thanks again.
  6. Terry McPherson
    Hey Peter,
    I want to do the same thing. Did you get it upgraded? If so could you send me the parts list.
    thanks
    Best to check in with Best to confirm with http://support.openbuilds.com/support/home
  8. Barzalou
    Barzalou Well-Known
    Hey Peter,
    I tried your link and it rejects my email address. So how can we contact support to upgrade the Workbee. I'm in the same situation.
    Thank you
  9. Peter Van Der Walt
    Use a more trusted email address? Gmail if you have none, etc.
    Or Email them at contact at openbuildspartstore.com (may still reject your email address if your email provider has been blacklisted)
  10. Barzalou
    Barzalou Well-Known
    I use gmail. Always have.
  11. Peter Van Der Walt
    Shouldn't reject your email then, grab a screenshot of the error?
  12. Barzalou
    Barzalou Well-Known
    I am confused, the login I use with openbuilds is with a username not an email address and it asks for an email for the username. Am I missing something?
  13. Peter Van Der Walt
    Seperate systems, seperate accounts:
    openbuilds.com = forums/builds
    support.openbuilds.com = support tickets, no login needed, fill in the form: Submit a ticket
    openbuildspartstore.com = online store
  14. Barzalou
    Barzalou Well-Known
    OK, so as you suggested above, I should confirm with http://support.openbuilds.com/support/home . So how do I do this then?
  15. Peter Van Der Walt
    Like this:
    #15 Peter Van Der Walt, May 5, 2021
