Workbee 1010
Discussion in 'CNC Mills/Routers' started by Armadillo Works, Feb 19, 2019.
  1. Gary Caruso
    Gary Caruso OpenBuilds Team
    Hi Armadillo, As long as "yellow and green" is a coil and "blue and red" is a coil you will be fine, A or B doesn't matter.
    To change the motor direction you can swap any one coil pair around for example "Y/G-B/R" to "G/Y-B/R" will turn in opposite directions.
    Keeping order consistent on a build helps for organization.
    Gary
  2. Armadillo Works
    Armadillo Works Well-Known
    Thanks! Gary.
    As with anything new it is always good to ask questions.
    By your avatar I assume you are into RC aircraft. So am I and my last building project was this Astro-Hog. Planning on using the Workbee to cut out parts.
    Roger
  3. Armadillo Works
    The Workbee is up and running!
    Need to make a few changes before I start making wood chips.
    sharmstr, GrayUK and Giarc like this.
  4. Armadillo Works
    Well the WorkBee will carve wood! Ran the Hello World test print and all went well.
    I needed to use a smaller bit but 1/4" is all I had handy.
    Thanks again to everyone who provide help.
