WorkBee 1010: Fusion360+CNC xPRO+OpenBuildsMachineDriver
Discussion in 'Controller Boards' started by Hector Beltran, Oct 24, 2018.
  1. Hector Beltran
    Hector Beltran Well-Known
    Hi guys,
    I am trying to figure what is the best workflow to get my designs cut by the WorkBee 1010. I really enjoy working with Fusion360; I do all my 3D printing and CNC designs here. I started with 3D printing, so it was fairly simple to extrapolate my skills to the CNC CAM functionality within Fusion360. Unfortunately, the post processor for the CNC xPRO doesn't exist in Fusion360. The stock Grbl cps gave me a few errors which prevented CNC jobs from starting with the Open Builds Machine Driver. I recently found in GitHub a cps for Grbl 0.9f which has allow me to start jobs, but the simulator (and actual CNC) movement is extremely slow making the workflow unusable.
    Ideally, I would like to keep using the Open Builds Machine Driver as my gcode sender but I am willing to explore other options. I use MacOS.
    Any ideas?
    Here is a copy of my cps based on the one found here Strooom/GRBL-Post-Processor
    Code:
    Custom Post-Processor for GRBL based Openbuilds-style CNC and Laser-Cutting machines
    Using Exiting Post Processors as inspiration
    For documentation, see GitHub Wiki : https://github.com/Strooom/GRBL-Post-Processor/wiki
    This post-Processor should work on GRBL-based machines such as
    * Openbuilds - OX, C-Beam
    * Inventables - X-Carve
    * ShapeOko / Carbide3D
    * your spindle is Makita RT0700 or Dewalt 611
    22/AUG/2016 - V1 : Kick Off
    23/AUG/2016 - V2 : Added Machining Time to Operations overview at file header
    24/AUG/2016 - V3 : Added extra user properties - further cleanup of unused variables
    07/SEP/2016 - V4 : Added support for INCHES. Added a safe retract at beginning of first section
    11/OCT/2016 - V5
    30/JAN/2017 - V6 : Modified capabilities to also allow waterjet, laser-cutting..
    25/JUL/2018 - V7 : Code review to eliminate a bug causing GRBL Error 33. Compared this postProcessor with the latest grbl.cps
    description = "Openbuilds Grbl";
    vendor = "Openbuilds";
    vendorUrl = "http://openbuilds.com";
    model = "Workbee";
    description = "Open Hardware Desktop Workbee CNC Router";
    legal = "Copyright (C) 2012-2018 by Autodesk, Inc.";
    certificationLevel = 2;
    extension = "nc";                                        // file extension of the gcode file
    setCodePage("ascii");                                    // character set of the gcode file
    //setEOL(CRLF);                                            // end-of-line type : default for Windows OS is CRLF (so that's why this line is commented out), change to CR, LF, CRLF or LFCR if you are on another OS...
    capabilities = CAPABILITY_MILLING | CAPABILITY_JET;        // intended for a CNC, so Milling, or 2D machines, such as lasers..
    tolerance = spatial(0.002, MM);                            // when linearizing a move, fusion will create linear segments which are within this amount of the actual path... Smaller values will result in more and smaller linear segments. GRBL.cps uses 0.002 mm
    minimumChordLength = spatial(0.25, MM);                    // minimum lenght of an arc, if Fusion needs a short arc, it will linearize... Problem with very small arcs is that rounding errors resulting from limited number of digits, result in GRBL error 33
    minimumCircularRadius = spatial(0.5, MM);                // minimum radius of an arc.. Fusion will linearize if you need a smaller arc. Same problem with rounding errors as above
    maximumCircularRadius = spatial(1000, MM);
    minimumCircularSweep = toRad(0.1);
    maximumCircularSweep = toRad(350);                        // maximum angle of an arc. 350 prevents Fusion from outputting full circles.. Although GRBL can do this (with some special GCODE syntax) it is more robust to not do it and stick to standard G2 G3 use.. Fusion will split a longer arc into multiple smaller G2 G3 arcs
    allowHelicalMoves = true;
    allowedCircularPlanes = (1 << PLANE_XY) | (1 << PLANE_ZX) | (1 << PLANE_YZ);    // This is safer (instead of using 'undefined'), as it enumerates the allowed planes in GRBL
    // user-defined properties : defaults are set, but they can be changed from a dialog box in Fusion when doing a post.
    properties =
        spindleOnOffDelay: 1.0,                // time (in seconds) the spindle needs to get up to speed or stop
        spindleTwoDirections : false,        // true : spindle can rotate clockwise and counterclockwise, will send M3 and M4. false : spindle can only go clockwise, will only send M3
        hasCoolant : false,                    // true : machine uses the coolant output, M8 M9 will be sent. false : coolant output not connected, so no M8 M9 will be sent
        hasSpeedDial : true,                // true : the spindle is of type Makita RT0700, Dewalt 611 with a Dial to set speeds 1-6. false : other spindle
        machineHomeZ : -10,                    // absolute machine coordinates where the machine will move to at the end of the job - first retracting Z, then moving home X Y
        machineHomeX : -10,
        machineHomeY : -10
    // creation of all kinds of G-code formats - controls the amount of decimals used in the generated G-Code
    var gFormat = createFormat({prefix:"G", decimals:0});
    var mFormat = createFormat({prefix:"M", decimals:0});
    var xyzFormat = createFormat({decimals:(unit == MM ? 4 : 6)});
    var feedFormat = createFormat({decimals:(unit == MM ? 1 : 3)});
    var rpmFormat = createFormat({decimals:0});
    var secFormat = createFormat({decimals:1, forceDecimal:true, trim:false});
    var taperFormat = createFormat({decimals:1, scale:DEG});
    var xOutput = createVariable({prefix:"X"}, xyzFormat);
    var yOutput = createVariable({prefix:"Y"}, xyzFormat);
    var zOutput = createVariable({prefix:"Z"}, xyzFormat);
    var feedOutput = createVariable({prefix:"F"}, feedFormat);
    var sOutput = createVariable({prefix:"S", force:true}, rpmFormat);
    var iOutput = createReferenceVariable({prefix:"I"}, xyzFormat);
    var jOutput = createReferenceVariable({prefix:"J"}, xyzFormat);
    var kOutput = createReferenceVariable({prefix:"K"}, xyzFormat);
    var gMotionModal = createModal({}, gFormat);                                             // modal group 1 // G0-G3, ...
    var gPlaneModal = createModal({onchange:function () {gMotionModal.reset();}}, gFormat); // modal group 2 // G17-19
    var gAbsIncModal = createModal({}, gFormat);                                             // modal group 3 // G90-91
    var gFeedModeModal = createModal({}, gFormat);                                             // modal group 5 // G93-94
    var gUnitModal = createModal({}, gFormat);                                                 // modal group 6 // G20-21
    function toTitleCase(str)
        // function to reformat a string to 'title case'
        return str.replace(/\w\S*/g, function(txt)
            return txt.charAt(0).toUpperCase() + txt.substr(1).toLowerCase();
    function rpm2dial(rpm)
        // translates an RPM for the spindle into a dial value, eg. for the Makita RT0700 and Dewalt 611 routers
        // additionally, check that spindle rpm is between minimum and maximum of what our spindle can do
        // array which maps spindle speeds to router dial settings,
        // according to Makita RT0700 Manual : 1=10000, 2=12000, 3=17000, 4=22000, 5=27000, 6=30000
        var speeds = [0, 10000, 12000, 17000, 22000, 27000, 30000];
        if (rpm < speeds[1])
            alert("Warning", rpm + " rpm is below minimum spindle RPM of " + speeds[1] + " rpm");
            return 1;
        if (rpm > speeds[speeds.length - 1])
            alert("Warning", rpm + " rpm is above maximum spindle RPM of " + speeds[speeds.length - 1] + " rpm");
            return (speeds.length - 1);
        var i;
        for (i=1; i < (speeds.length-1); i++)
            if ((rpm >= speeds[i]) && (rpm <= speeds[i+1]))
                return ((rpm - speeds[i]) / (speeds[i+1] - speeds[i])) + i;
        alert("Error", "Error in calculating router speed dial..");
        error("Fatal Error calculating router speed dial");
        return 0;
    function writeBlock()
        writeWords(arguments);
    function writeComment(text)
        // Remove special characters which could confuse GRBL : $, !, ~, ?, (, )
        // In order to make it simple, I replace everything which is not A-Z, 0-9, space, : , .
        // Finally put everything between () as this is the way GRBL & UGCS expect comments
        writeln("(" + String(text).replace(/[^a-zA-Z\d :=,.]+/g, " ") + ")");
    function onOpen()
        // here you set all the properties of your machine, so they can be used later on
        var myMachine = getMachineConfiguration();
        myMachine.setWidth(824);
        myMachine.setDepth(780);
        myMachine.setHeight(122);
        myMachine.setMaximumSpindlePower(700);
        myMachine.setMaximumSpindleSpeed(30000);
        myMachine.setMilling(true);
        myMachine.setTurning(false);
        myMachine.setToolChanger(false);
        myMachine.setNumberOfTools(1);
        myMachine.setNumberOfWorkOffsets(6);
        myMachine.setVendor("OpenBuilds");
        myMachine.setModel("Workbee CNC 1010");
        myMachine.setControl("GRBL V0.9j");
        writeln("%");            // open the file with a '%'. GRBL does not really do anything with this, but as this is so part of classic GCODE, I decided to leave it in :-)
        var productName = getProduct();
        writeComment("Made in : " + productName);
        writeComment("G-Code optimized for " + myMachine.getVendor() + " " + myMachine.getModel() + " with " + myMachine.getControl() + " controller");
        writeln("");
        if (programName)
            writeComment("Program Name : " + programName);
        if (programComment)
            writeComment("Program Comments : " + programComment);
        var numberOfSections = getNumberOfSections();
        writeComment(numberOfSections + " Operation" + ((numberOfSections == 1)?"":"s") + " :");
        for (var i = 0; i < numberOfSections; ++i)
            var section = getSection(i);
            var tool = section.getTool();
            var rpm = section.getMaximumSpindleSpeed();
            if (section.hasParameter("operation-comment"))
                writeComment((i+1) + " : " + section.getParameter("operation-comment"));
            else
                writeComment(i+1);
          if (section.workOffset > 0)
               writeComment("  Work Coordinate System : G" + (section.workOffset + 53));
            writeComment("  Tool : " + toTitleCase(getToolTypeName(tool.type)) + " " + tool.numberOfFlutes + " Flutes, Diam = " + xyzFormat.format(tool.diameter) + "mm, Len = " + tool.fluteLength + "mm");
            if (properties.hasSpeedDial)
                writeComment("  Spindle : RPM = " + rpm + ", set router dial to " + rpm2dial(rpm));
            else
                writeComment("  Spindle : RPM = " + rpm);
            var machineTimeInSeconds = section.getCycleTime();
            var machineTimeHours = Math.floor(machineTimeInSeconds / 3600);
            machineTimeInSeconds  = machineTimeInSeconds % 3600;
            var machineTimeMinutes = Math.floor(machineTimeInSeconds / 60);
            var machineTimeSeconds = Math.floor(machineTimeInSeconds % 60);
            var machineTimeText = "  Machining time : ";
            if (machineTimeHours > 0)
                machineTimeText = machineTimeText + machineTimeHours + " hours " + machineTimeMinutes + " min ";
            else if (machineTimeMinutes > 0)
                machineTimeText = machineTimeText + machineTimeMinutes + " min ";
            machineTimeText = machineTimeText + machineTimeSeconds + " sec";
            writeComment(machineTimeText);
        writeln("");
        writeBlock(gAbsIncModal.format(90), gFeedModeModal.format(94));
        writeBlock(gPlaneModal.format(17));
        switch (unit)
            case IN:
                writeBlock(gUnitModal.format(20));
                break;
            case MM:
                writeBlock(gUnitModal.format(21));
                break;
        writeln("");
    function onComment(message)
        writeComment(message);
    function forceXYZ()
        xOutput.reset();
        yOutput.reset();
        zOutput.reset();
    function forceAny()
        forceXYZ();
        feedOutput.reset();
    function onSection()
        var nmbrOfSections = getNumberOfSections();        // how many operations are there in total
        var sectionId = getCurrentSectionId();            // what is the number of this operation (starts from 0)
        var section = getSection(sectionId);            // what is the section-object for this operation
        // check RadiusCompensation setting
        var radComp = getRadiusCompensation();
        if (radComp != RADIUS_COMPENSATION_OFF)
            alert("Error", "RadiusCompensation is not supported in GRBL - Change RadiusCompensation in CAD/CAM software to Off/Center/Computer");
            error("Fatal Error in Operation " + (sectionId + 1) + ": RadiusCompensation is found in CAD file but is not supported in GRBL");
            return;
        // Insert a small comment section to identify the related G-Code in a large multi-operations file
        var comment = "Operation " + (sectionId + 1) + " of " + nmbrOfSections;
        if (hasParameter("operation-comment"))
            comment = comment + " : " + getParameter("operation-comment");
        writeComment(comment);
        writeln("");
        // To be safe (after jogging to whatever position), move the spindle up to a safe home position before going to the initial position
        // At end of a section, spindle is retracted to clearance height, so it is only needed on the first section
        // it is done with G53 - machine coordinates, so I put it in front of anything else
        if(isFirstSection())
            writeBlock(gAbsIncModal.format(90));    // Set to absolute coordinates
            if (isMilling())
                writeBlock(gFormat.format(53), gMotionModal.format(0), "Z" + xyzFormat.format(properties.machineHomeZ));    // Retract spindle to Machine Z Home
        // Write the WCS, ie. G54 or higher.. default to WCS1 / G54 if no or invalid WCS in order to prevent using Machine Coordinates G53
        if ((section.workOffset < 1) || (section.workOffset > 6))
            alert("Warning", "Invalid Work Coordinate System. Select WCS 1..6 in CAM software. In Fusion360, set the WCS in CAM-workspace | Setup-properties | PostProcess-tab. Selecting default WCS1/G54");
            writeBlock(gFormat.format(54));  // output what we want, G54
       else
           writeBlock(gFormat.format(53 + section.workOffset));  // use the selected WCS
        // Insert the Spindle start command
        if (tool.clockwise)
            writeBlock(sOutput.format(tool.spindleRPM), mFormat.format(3));
        else if (properties.spindleTwoDirections)
            writeBlock(sOutput.format(tool.spindleRPM), mFormat.format(4));
        else
            alert("Error", "Counter-clockwise Spindle Operation found, but your spindle does not support this");
            error("Fatal Error in Operation " + (sectionId + 1) + ": Counter-clockwise Spindle Operation found, but your spindle does not support this");
            return;
        // Wait some time for spindle to speed up - only on first section, as spindle is not powered down in-between sections
            onDwell(properties.spindleOnOffDelay);
        // If the machine has coolant, write M8, else write M9
        if (properties.hasCoolant)
            if (tool.coolant)
                writeBlock(mFormat.format(8));
            else
                writeBlock(mFormat.format(9));
        var remaining = currentSection.workPlane;
        if (!isSameDirection(remaining.forward, new Vector(0, 0, 1)))
            alert("Error", "Tool-Rotation detected - GRBL only supports 3 Axis");
            error("Fatal Error in Operation " + (sectionId + 1) + ": Tool-Rotation detected but GRBL only supports 3 Axis");
        setRotation(remaining);
        forceAny();        // this ensures all axis and feed are output at the beginning of the section
        // Rapid move to initial position, first XY, then Z
        var initialPosition = getFramePosition(currentSection.getInitialPosition());
        writeBlock(gAbsIncModal.format(90), gMotionModal.format(0), xOutput.format(initialPosition.x), yOutput.format(initialPosition.y));
        writeBlock(gMotionModal.format(0), zOutput.format(initialPosition.z));
    function onDwell(seconds)
        writeBlock(gFormat.format(4), "P" + secFormat.format(seconds));
    function onSpindleSpeed(spindleSpeed)
        writeBlock(sOutput.format(spindleSpeed));
    function onRapid(_x, _y, _z)
        var x = xOutput.format(_x);
        var y = yOutput.format(_y);
        var z = zOutput.format(_z);
        if (x || y || z)
            writeBlock(gMotionModal.format(0), x, y, z);
            feedOutput.reset();                                // after a G0, we will always resend the Feedrate... Is this useful ?
    function onLinear(_x, _y, _z, feed)
        var f = feedOutput.format(feed);
        if (x || y || z || f)
            writeBlock(gMotionModal.format(1), x, y, z, f);
    function onRapid5D(_x, _y, _z, _a, _b, _c)
        error("Tool-Rotation detected but GRBL only supports 3 Axis");
    function onLinear5D(_x, _y, _z, _a, _b, _c, feed)
    function onCircular(clockwise, cx, cy, cz, x, y, z, feed)
        var start = getCurrentPosition();
        switch (getCircularPlane())
            case PLANE_XY:
                writeBlock(gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), iOutput.format(cx - start.x, 0), jOutput.format(cy - start.y, 0), feedOutput.format(feed));
                break;
            case PLANE_ZX:
                writeBlock(gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), iOutput.format(cx - start.x, 0), kOutput.format(cz - start.z, 0), feedOutput.format(feed));
                break;
            case PLANE_YZ:
                writeBlock(gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), jOutput.format(cy - start.y, 0), kOutput.format(cz - start.z, 0), feedOutput.format(feed));
                break;
            default:
                linearize(tolerance);
    function onSectionEnd()
        xOutput.reset();                        // resetting, so everything that comes after this section, will get X, Y, Z, F outputted, even if their values did not change..
        yOutput.reset();
        zOutput.reset();
        feedOutput.reset();
        writeln("");                            // add a blank line at the end of each section
    function onClose()
        writeBlock(gAbsIncModal.format(90));    // Set to absolute coordinates for the following moves
        if (isMilling())                        // For CNC we move the Z-axis up, for lasercutter it's not needed
            writeBlock(gAbsIncModal.format(90), gFormat.format(53), gMotionModal.format(0), "Z" + xyzFormat.format(properties.machineHomeZ));    // Retract spindle to Machine Z Home
        writeBlock(mFormat.format(5));        // Stop Spindle
            writeBlock(mFormat.format(9));        // Stop Coolant
        onDwell(properties.spindleOnOffDelay);        // Wait for spindle to stop
        writeBlock(gAbsIncModal.format(90), gFormat.format(53), gMotionModal.format(0), "X" + xyzFormat.format(properties.machineHomeX), "Y" + xyzFormat.format(properties.machineHomeY));    // Return to home position
        writeBlock(mFormat.format(30));        // Program End
        writeln("%");        // EndOfFile marker - GRBL doesn't use it / ignores it, but it's so much tradition, so I left it in..
  3. ImAPilotICanFly
    bump! i am a fusion user as well and if this doesnt work with fusion...i need to do some research!
  4. Hector Beltran
    It works fine. You just need to be careful with the offsets when you save your post-process. Also, I strongly recommend limit switches. One last tip. Make sure you set the dimensions of your maximum cutting area on your x-pro. Mine are a few millimeters smaller than the specs.
  5. Hector Beltran
    Use strooom’s post processor. Save it in the correct location, so you can select it from the post-process window in Fusion..
    I’ve done a few projects with it, and it works well.
  6. ImAPilotICanFly
    Dowloaded. We'll see how that works!
  7. sharmstr
    It works fine. There are a few things to look out for. I outlined them starting here: OpenBuilds CONTROL Software
    If you have any issues, post them back in this thread.
