wires hot to touch
Discussion in 'General Talk' started by Beth Rhodes, Aug 17, 2022.
  1. Beth Rhodes
    I am connecting wires from power box to black box and they feel hot. Why
  2. Beth Rhodes
    I have checked with a volt meter that the output from the yellow and black wires is 24 volt. And that the wires have not been reversed. When I plug in the adapter for the wires to the black box they start to get hot. It is set at 24 volts. I don't actually have the black box switched on. What am I doing wrong? Is this normal?
    Thanks for any thoughts and help!!
    Beth
  3. Beth Rhodes
    I then connected hot yellow wire to v+ and neutral black wire to V- on the power box. I have then attached yellow to the right 24v side of the adapter and the black to the Gnd left side. I have double and triple checked everything is tight and to the best of my knowledge in the right place.
    DROK 48V Power Supply, AC 110V/220V to DC 0-48V 10A 480W Buck Converter, Adjustable Variable LED Adapter Regulated 5V 12V 24V 30V 36V 48V Volt Voltage Transformer 10A Amp Charger for Lab CCTV Radio
    This is where I got the black and yellow wire from Amazon:
    18/4 AWG Shielded CNC Wire (50FT) — Flexible Stranded Shielded 18-Gauge 4-Conductor Cable for Stepper Motors, CNC Machines, NEMA Motors, VFD Spindles, CNC Routers, 3D Printers and more!
    BlackBox is 24v! See the text on the case itself right at the power socket, as well as docs.openbuilds.com
    48V will damage your BlackBox
  5. Beth Rhodes
    The power source I have is adjustable with the turn knob. I shows on a digital dial what the volts are set at.. I have changed it to have an output of 24 Volts. Am I missing something or misunderstanding how it works?
  6. Beth Rhodes
    Please tell me I haven't damaged anything. I have only had it connected for a few seconds at a time. Never more than a minute.
    If its always been on 24v it should be OK. Contact the store via Support > new ticket for further support.
  8. Beth Rhodes
  9. David the swarfer
    Wires get hot because they are carrying more current than their thickness warrants.
    no, this is not normal.
    do they still get hot when not plugged into the blackbox?
    if so then there is a problem in the plug.
    if not then there is a problem in the blackbox
