Good Evening All. Today I have spent the afternoon building the new workbench for the Workbee CNC 1000 X 750 leed screw from Ooznest. One must say I am a tad EXCITED!!!! New toy for the man cave!!! I have a router coming with the CNC however I have been looking at water cooled spindle options as I will spend quite a bit of time in the garage whilst the CNC is running, and I'd rather not have to wear ear defenders the whole time... The router I have looked at is one of ebay, a 1.5kW version (link below) 1.5KW 220V Water cooled Spindle Motor ER16 CNC Router&1.5KW Inverter&Clamp【UK】 | eBay I guess my questions are as follows: - Is this compatible with the WorkBee form Ooznest? - Is this powerful enough to cut Hardwood for Guitars? - Is this able to cust Aluminium I'm new to the CNC world and whilst I have made a number of guitars by hand, I and hoping to use a hybrid workflow allowing me to do the fun bit by hand, and the more precision/bits with the CNC. Thank you for taking the time to read my ramblings, and any feedback sharing your experience would be greatly received. Cheers All Regards Colin.
Please do a Search for "Chinese Spindle", in the top right-hand Search panel, to get yourself up to speed on all Spindle matters.
Hi Colin Its Colin here Uncanny that I have also just purchased the 1000x750 screw driven Workbee model from Ooznest Like you I'm also a novice in certain ways to desktop CNC. I have the Makita spindle already so didn't need one from order I too am in the fros of building a new bench for the new toy as you call it, You will find many well educated folks here very helpful and will keep you on the straight and narrow with all things CNC I haven't got the machine up and running yet but I gather noise is going to be a bug bear so I'll be following your thread with interest. Throw up a few pics of your bench Regards C
I just today fitted a 2.2k to my new workbee. Haven't started it up yet but I couldn't see any obvious flex. Will let you know how I get on tomorrow when it gets started up and calibrated. This machine is an absolute beast
Good Morning All. Wow, quite a number of responses and some further learning identified. So Collett sizes @Gary Caruso - Thank you for the table, I hadn't realised/seen this table on the listings I was looking at. It is interesting that the 65mm diameter spindle is so much lighter, however, it appears to be so much harder to find. The 80mm diameter is the more popular version on the eBay stores. @Alex Chambers - Well noted. A quick google of ER11 and what size shank it will hold reveals 1/4" shank, and I think I 1/8" depending on Collet sizes? I have been trying the find some comparison on Water Cooled vs Air Cooled, I can only seem to find reviews from 2015, I think the comments made are likely to to be a bit dated. Does anyone have any first-hand experience of AC vs WC? @structured light - Nice picture - Very interested in how your test goes, can you share which spindle you purchased? 2.2Kw, that's a lot of power. At a weight of around 5KG that would answer any weight questions. @Colin Mccourt - A Bench off I hear - This project gave me a reason to have a big clear up in the Man Cave. I have managed to re-commission my wood Leith which has been tucked out the way for too long. I'll share some pics once have things progressing, let me know how you get on as well. Right, it's Sunday Morning in sunny Cambridgeshire - Time to put on the breakfast. Thanks again for your replies. Regards Colin.
Hahaha Hardly a "bench off" C...I just want a level surface so nothing fancy just a table type affair 4 legs and a shelf below, although a drawer and a laptop shelf would be nice not to mention a radial arm for some wire and dustpipe management lol...Good Luck with the build looking forward to see how you progress with the guitars... Regards C
Looks cosy in there C lol I cleared the garage total de-clutter-isation...I'd no room for a new bench so I had to commandeer an old one and rig up a new surface board and sq. up. could do with some leveling threaded feet though. Are you going to have yours encased for noise/dust etc. Regards C
ER11 has good range for an openbuilds machine, google er11 collet set typical is 1-7mm Air cooled even heavier and bigger, I'm sure you can get an 80mm dia to work, but remember your C beam Z beam is 80 mm wide.. so where will the mount bolt to? Will have to make or buy a different mount or adapter plate. With 65mm you can use the Makita router with the same mount hardware. Can't find 65mm motors? ebay search "WATER-COOLED 65MM 1.5KW ER11" I see loads of them. Cheers Gary
Hi Chaps - I have found this on AliExpress: US $172.25 35% OFF|1.5kw Water Cooled Spindle Motor & 1.5kw VFD / Interver & 65mm clamp & pump /pipe& 13pcs ER11(1 7mm) For CNC Router-in Machine Tool Spindle from Tools on Aliexpress.com | Alibaba Group I think this ticks the boxes.. Can anyone give a nod to say "Yep that will work" or "Nooooooooo" As always much appreciated for your input. Regards Colin
I have an AMB 1050 fme-p. Planning to move that to my workbee. Super precision and ER16. ER11 would make my cnc life very annoying and time consuming at times.
