What could cause this?
Discussion in 'CAD' started by kyle corbin, Feb 8, 2023.
  1. kyle corbin
    Hey everyone for context i am using Fusion 360 and openbuilds controller. every time i load a project into the controller the "project is not on the "cutting area" or only half.
    where are you setting the origin in your drawing for the CAM?
    CONTROL expects it to be near,left,top of the material, but it does adjust the display according to the GRBL settings and current WCS
    this also depends on your setttings in the controller. if you have homing enabled and working, and have set the axis sizes, then CONTROL can display the right stuff in the right place.
  3. kyle corbin
    Home on fusion is Top right view. i do have the home probe enable but still will only be able to only cut of my project.
