Waiting for USB
Discussion in 'Controller Boards' started by William Harper, Jan 23, 2020.
  1. William Harper
    I have an Lead 1010 with V3 Sparks controller and have been using it for quite some time with no problems. I just purchased a 4.2 Jtech laser and set it up to use on my 1010. Now I can't connect via USP to my Lead or Jtech. Below is a screen shot of my controller. Any help would be greatly appreciated. Thanks.
    Staff Member Moderator Project Maker Builder Resident Builder
    Disconnect the new wiring you added and try again, probably while wiring the laser you made a short or miswiring mistake somewhere preventing the board from booting.
  3. William Harper
    I'll do that.
  4. William Harper
    I removed the new wiring and restarted. I get the same message.
    Possible you miswired something and damaged the board?
    1) If it was all working up to then, the question "what happened" points to adding wiring
    2) As it was all working up to then, the PC, software, drivers etc are unlikely to be the issue
    3) check Device manager > Ports while plugging and unplugging the device for clues
    4) take it one step further, disconnect everything except USB and test then
    5) Try a different PC just in case
  • About Us
    [email protected]
  • Follow us on Instagram
  • Like us on Facebook
    Donate to Open Source
