VFD connection to ARDUINO CNC
Discussion in 'CNC Mills/Routers' started by DavidCNC2017, Mar 19, 2021.
  1. DavidCNC2017
    Hello,
    Recently I bought this
    Can anybody help me how to connect it to ARDUINO to be possible to switch it on/off and set the speed via Openbuilds control software?
    Thank You
  3. DavidCNC2017
    Thank You for Your response. When I wrote Arduino I mean controller "based" on Arduino.
    Actually it is Phoenix CNC Controller:
    As You can see it has all necessary pins to connect VFD. The problem is actually in VFD itself. Which one here are spindle enable and PWM+ and PWM- ?
    OK, it has 0-10v - follow the link I gave earlier - at the very bottom is links to wiring written up by forum members
    DavidCNC2017 likes this.
  5. DavidCNC2017
  6. Netechsys
    Netechsys Journeyman
  7. DavidCNC2017
    Yes, thanks, I know it. My controller already has this module onboard.
    It was just about finding out in VFD pins, which one should be connected to the controller.
