VFD and IOT
Discussion in 'Controller Boards' started by Hellsbellsidaho, Oct 27, 2019.
  1. Hellsbellsidaho
    How do I connect both the IOT and a 0-10v VFD to the Blackbox?
    Grbl only has one Spindle output so that would be an either/or situation for spindle control
    Unless you want to use the IOT relay for something else, then use the Coolant output (M8/M9 to turn it on/off)
  3. Hellsbellsidaho
    Actually I wanted to use the IOT relay for the spindle water pump so it sounds like I can just connect the IOT to the coolant output?
    :) Thanks for the extra details, it helps to have it
    Yes, according to the datasheet (attached), the IOT Relay can use a control signal of 3-48v DC (so the 24v Coolant output should do nicely)
    Haven't tested if personally, but please let me know if you have any issues
  5. Hellsbellsidaho
    Thanks, Peter. I will give it a try today.
