Vcarve Pro 2 sided copy array question
Discussion in 'CAD' started by rbrown55, Dec 27, 2023.
  1. rbrown55
    rbrown55 New
    Hello and Happy almost new year
    Can anyone help me figure out how to copy both sides of a 2 sided project and run the copy array for both sides at the same time? is it even possible? Doesn't seem like it cause the gap i set wouldnt work for both sides but I was hoping there is a way and it simply applies the gap to the side currently selected.
  2. Christian James
    Christian James Journeyman
    Not 100% certain what exactly you mean. However, as far as the first question goes, {Can anyone help me figure out how to copy both sides of a 2 sided project}
    One way would be to create an STL file from the 3D object, then load the STL into Netfabb and perform a slice operation. Just save both halves as 2 separate files.
  3. Giarc
    I am also not quite sure I understand what it is you are trying to do. Are you not just doing a two sided cut because you do not have thick enough stock and your intention is to glue two sides together? Is it an stl file you are trying to cut, or just a dxf file?
