V-Carving for free.
Discussion in 'Other Software' started by Tweakie, Feb 4, 2014.
  1. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Once our routers have been constructed and tested the search is on for free software to create the tool-paths necessary to make our stuff.
    V-Carving can produce excellent results for house names, signs etc. and the free software F-Engrave http://www.scorchworks.com/Fengrave/fengrave.html does just this and more.
    This is just an offcut from an old (unwanted and cheaply purchased) English Oak bookcase but it serves to illustrate the principle of V-Carving.
    Tweakie.
    gazingm42, Evan F, Mark Carew and 4 others like this.
  2. Mark Carew
    You rock Tweakie this looks fantastic! I think this should be a resource for sure :thumbsup:
    I just pick up a cent table leaf someone was throwing out the other day. Its about 1" thick wood that i just could not let go to the trash. I have to try a V bit carving on it now!
  3. Tweakie
    Moderator
    Thanks Mark.
    I normally use commercial engraving software (which cost in excess of $2000) but just as an example of what F-Engrave can do it was used to create the tool path for this 0.5mm text height rotary engraving. I do appreciate that not everybody would want to do this but it does, I think, show the versatility of this software.
    Tweakie.
    Serge E. and Mark Carew like this.
  4. Rick 2.0
    What bit did you use for this?
    Thanx.
  5. Tweakie
    Moderator
    Hi Rick,
    It was a 20 Deg. engraving point - only one out of a pack of five (imported from China) was suitable, the rest had too much run-out for work this size.
    Tweakie.
    Rick 2.0 likes this.
  6. Donald Gibbs
    I downloaded the program but I'm not smart enough to unzip it. Help!!!!!!
  7. Tweakie
    Moderator
    Hi Donald,
    Unzips OK here - perhaps you could try using 7zip http://www.7-zip.org
    Hope this helps.
    Tweakie.
