New to the CNC World. I have mounted a crosshair laser to the machine to make establishing the X & Y Work Zeros easier. Once I have the cross hairs on the work x and y zero point (in this case the corner of the work) I run the following macro to reposition the router over the corner of the work. T1 G17 G21 G90 G0x-5.3Y5.1 M2 Then I reset my x and y work zeros manually. My question is is there code that can be added at the end of this simple little macro to reset the x and y zero without doing it manually?
Use G10: G Codes CONTROL uses it for the Setzero buttons, for example: OpenBuilds-CONTROL/index.html at 295fbf2bbc93c071facd202bc5323b39775ead32 · OpenBuilds/OpenBuilds-CONTROL
