Using digital calipers to calibrate CNC router?
Discussion in 'CNC Mills/Routers' started by jeffmorris, May 8, 2020.
  1. jeffmorris
    jeffmorris Journeyman
    Is it possible to use digital calipers to calibrate CNC router? I tried to calibrate my CNC router using a ruler but I can't see exactly where the bit is on the ruler. If so, how can I do this?
  2. Giarc
    You should be able to, but it s a much shorter distance and my experience harder to read and touchier. I have found a V bit and a ruler to be the easiest and most accurate. The next build I will probably use one of my cheap 10 degree 1/8" super pointy PCB milling v bits.
  3. David the swarfer
    in my experience that is too short for calibration except on Z.
    use the longest ruler that will fit, and move the head along it the longest distance you can manage.
    use a flashlight and magnifying glass to see the tool tip and markings.
    use a pointed tip like an engraving bit if you have one. if not use a 2 flute carbide bit and look down one flute for the measurement, by looking down the flute you can avoid parallax errors.
    Giarc likes this.
  4. Giarc
    I also used a camera to take a picture as straight on as possible so I could zoom in and see it better, but that was before I got glasses.
  5. Christian James
    Christian James Journeyman
    Yes, definitely invest in a long ruler. For the Lead, a 2'6" long ruler would do the job.
    #5 Christian James, May 11, 2020
  6. jeffmorris
  7. Giarc
    I have an "iGaging ABSOLUTE ORIGIN 0-12" Digital Electronic Caliper" and like it. It is not what you asked about, but I ave not had an issue with the brand or the product I purchased. That being said, I like this and a V-bit for calibration, especially the price.
    40 in. Aluminum Ruler
