Use Y axis as X axis
Discussion in 'CNC Mills/Routers' started by Mech.res, Nov 25, 2020.
  1. Mech.res
    Mech.res New
    Hey everyone! This is my first post here so sorry if this is a little rough. I have a Workbee CNC machine with a Blackbox motion controller. My machine is deeper than it is wide, my preference is for it to be wider and shallower so I'm just orienting it 90 degrees to how its intended (what was the side is now the front). How/Can I reconfigure the Blackbox to treat the two Y axis outputs as the X axis, and the one X axis as the Y axis to match its new orientation?
    Id also like to accomplish this without splitting the output to the one X axis to power both Y motors, I'm hoping I can solve this in settings somewhere instead.
    Thanks for any help!
    Jaelen
    You will put first X motor on X.
    Y motor on Y
    Second X motor on Y2
    And Z motor on Z
    Then refer to docs:blackbox:jumper-slaveaxis [OpenBuilds Documentation] to assign Y2 as an X axis driver
    sharmstr and David the swarfer like this.
  3. Mech.res
    Mech.res New
    Thanks so much! That's perfect.
