Use INTERFACE without internet connection
Discussion in 'Interfaces' started by ButlerBowls, Oct 2, 2021.
  1. ButlerBowls
    I am in the middle of internet outage due to my ISP. I seem to be unable to use my INTERFACE controller because I don't have access to the INTERFACE network. When the INTERFACE boots up and gets to the wifi; connecting... it won't fail. I need it to fail or something so that I can change the network to be something else.
    If the above is not doable how can I use my CNC machine without the INTERFACE please? I am not aware if I can use my laptop while the INTERFACE is available (I get i can simply disconnect the cable but will the settings recognize the laptop now?)
    Thank you,
    Interface does not need internet. Is your firmware up to date (v1.47) as it should just timeout if your network is not found
    You can of course use CONTROL any time too. Just plug the USB back into your BlackBox
