USB Pendant for CONTROL
Discussion in 'General Talk' started by Rhett E, Nov 24, 2020.
  1. Rhett E
    Rhett E Well-Known
    I've read some older threads covering this topic but was hoping there is new information. I'm looking for a physical device, other than a phone, for jogging. It sounds like a small USB keypad or video game controller can be programmed using keystrokes/shortcuts within control? If so, is there a keypad or controller recommended along with keymapper software?
    I appreciate the mobile pendant and I know the incredible amount of work that has gone into it. Personally, I work with Electronic Medical Record software all day which includes mobile device support so the last thing I want to do when I've escaped to the garage is have a phone in the same room. Maybe I'm just old fashioned :)
    Giarc likes this.
    I used a usb numberpad for a while, it works well.
    Now I use a generic USB game controller and map the controls to shortcuts using Qpoypad on Linux.
    I have not tried it on Windows yet but mapping software does exist, google will find it.
    yeah, I often leave my phone next to the bed for the whole weekend and catch up on messages when I really feel like it, and work messages will wait till Monday.
    Giarc, Rhett E and Peter Van Der Walt like this.
  3. David the swarfer
  4. JustinTime
    JustinTime Veteran
    I use ShuttleExpress with Mach3. I can't remember if I had to install a driver for it since it's been many years since I first installed it and I still use it. It's not wireless but this doesn't bother me.
    The link is for Amazon.ca. Google it and you'll find it WAY cheaper.
    Rhett E likes this.
  5. Rhett E
    Rhett E Well-Known
    There are some wireless USB game controllers that would be very convenient. Would those be a problem as opposed to wired USB?
  6. David the swarfer
    I have had problems with wireless mice so no, I don't think wireless is a good idea when controlling sharp spinning cutters <-:
    Rhett E and sharmstr like this.
  7. Rhett E
    Rhett E Well-Known
    A follow-up to this. I ordered a wired USB game controller from amazon and installed Antimicro as suggested. Was up and running in 20 minutes with zero issues and I love it. Can't imagine not having it.
    Unrelated, is there a way to speed up the jogging? I completely understand the speeds are pre-set to recommended settings. I'm not looking to set any land speed records but just a little more kick. Machine is a LEAD 1515 with high torque motors.
  8. Giarc
    Which controller did you get? I use an Xbox controller with my machine that uses Estlcam, but I would love to add another controller to my lathe.
    You can change the jog speed where the red arrow points. Type it in the box. I think it defaults to 5000mm/min. If your grbl settings are such that it can't go faster than 5000mm/min, adding a higher number here will not matter.
    #8 Giarc, Dec 4, 2020
    Rhett E likes this.
  9. DarkPenguin
    DarkPenguin Well-Known
