USB Mach3 Setup
Discussion in 'CNC Mills/Routers' started by Aleksejs, Jul 27, 2019.
  1. Aleksejs
    Aleksejs New
    Hey guys!
    So far i have built all my electrical stuff together and im ready for setting it up and testing it.
    Currently im on a step setup spindle controll through my motion card which is MKX-4 Mach3.
    Has anyone used/uses this card?
    What have i done so far is:
    Connect my VFD HY03D023B to motion card using following connections
    from motion card FWD(spindle) to FWD on VFD
    from motion card DCM(spindle) to DCM on VFD
    from motion card ACM( spindle) to ACM on VFD
    from motion card AVI(spindle) to V1 on VFD
    from motion card 10V In(spindle) to 10V on VFD
    After using these connections i cant my spindle through mach3 software. Neither on/off, neither RPM.
    Do i have to use some speficic input/output settigs?
    I have also programmed my VFD with many stuff and it works fine if i use manuall controlls on VFD.
    For motion controll card i have change PD001 and PD002 to value 1 so it can be controlled externaly.
    Here are some pictures that might help i hope :D
  2. jeffmorris
    jeffmorris Journeyman
  3. Aleksejs
    Aleksejs New
    Thanks, so far i have managed to setup spindle so it turns on/off from Mach3 software, but i cant really seem to make it controll the RPMs correctly.
    I think it could be because of my VFD settings. Does anyone have a same VFD as i do?
  4. jacevedo
    jacevedo New
    Yo pase por el mismo problema y mejor lo resolvi a través del convertidor USB-RS485 modbus.
