Usb Connection problem
Discussion in 'General Talk' started by Fa.Steinhauser, Mar 10, 2019.
  1. Fa.Steinhauser
    Hy there, my Name is Markus i am from Austria ,
    and i have a problem with the Usb Connection .
    I use the Usb Controller Mk 3/4 , if i open the Openbuild Controler Software on my Lap Top , I cant connect the Software with the controller card .
    The Software say permanent "waiting for Usb " there is no Usb Port choose.
    The usb controller is on !
    Its my first project !
    Thanks for Help
    Greetings Markus
  2. Fa.Steinhauser
    I tryed it again …..with a other Computer .
    it says: No supported Firmware detected. Closing Port 6 .
    I also tryed to conect the two contacts on the usb Controller mk3/4 to load a new Firmware …...but Nothing helps ..
    Does anyone have an idea ?
    Thank You Markus
  3. sharmstr
    sharmstr Master
    Award likes this.
  4. Award
    Award Well-Known
    Hello Markus,
    What controller card are you using?
    I've got an xPro v3 and if I remember correctly I had to install the FTDI drivers: Virtual COM Port Drivers
    Adam
  5. Award
    Award Well-Known
    Ha Ha Ninja'd by Sharmstr while writing the previous message
  6. Fa.Steinhauser
    Thank You very much Guys ! I will try that !
  7. Rick 2.0
    I don't believe the Mk3/4 is compatible with the Openbuilds software. It runs an entirely different processor. It should be using the planet-cnc software that came with it.
    Mark Carew and sharmstr like this.
  8. Gary Caruso
    Gary Caruso OpenBuilds Team
    Right, Check the software information on the product page, lots of info there....
    Assembly Build / Support / Documentation
    You can connect the CNC USB controller Mk3/4 to the DQ542MA Stepper Motor Driver. Installation instructions can be found here.
    How to Activate Your License
    - Download and install latest software Software - PlanetCNC
    - Activate software using your license - open “License activation” dialog and paste your registration key.
    Software Download Support:
    http://planet-cnc.com/software/
    Planet CNC • View forum - Software
    After you receive license code from us, in PlanetCNC TNG software click Help/License Management/My Licenses
    User Manual: http://planet-cnc.com/wp-content/uploads/2016/03/CNCUSBControllerMk34.pdf
    HOW TO SET UP A MACHINE USING THE CNC USB MK3/4 BOARD
  9. Fa.Steinhauser
    Hello , Thank You very much for all Your answers.
    It works …..i am Little bit sad , that it doesnt work with the openbuild Maschine Driver .
    But the cnc planet Driver works !
    Thank You very very much !!!!!
    GrayUK and Mark Carew like this.
  10. Fa.Steinhauser
    On more Thing !
    I want to install a Cold Glue Ventil on my acro System from Openbuilds .
    My whole Setup :
    Acro System
    Nehma17" Motors
    DQ542MA Motordriver
    Cnc Usb Driver Mk 3/4
    Cnc Planet Maschinedriver software
    The Ventil works with a coil ( 8Volt approx. 0,5 amps) .
    The plan is to apply gluedots on a papersheed.
    For this i want to use the pwm Signal from the mk3/4 Controller …...or is it a better idea to lay out the gluelines in very smal dots in the G-Code file?
    And wich Out Signal is the best for my Ventil /Coil ?
    Thank You very much
    Greetings from Austria
    Markus
  11. Rick 2.0
    These are questions best asked on the Planet-CNC forum. The number of forum members here that have experience with the Mk3/4 is somewhat limited so you may not get as good of answers here as you would get there.
  12. Peter Van Der Walt
    Staff Member Moderator Project Maker Builder Resident Builder
    OpenBuilds CONTROL is for Grbl based machines.
    USBCNC is a proprietary protocol (closed source) from PlanetCNC (So we cannot support it as its not known/documented)
  13. Fa.Steinhauser
    Hy Peter , ok i see.
    But thats a Little frustrating for me .
    No one told me that , if i was collecting all my parts for the acro System on openbuilds , someone from openbuilds guidet me online to by the correct parts.
    In Nov/ december there was only the mk3/4 Controller available ,so i both it .
    Now it is a very hard Job to find all the Settings four the planet cnc Controller Software ...
  14. Peter Van Der Walt
    Reach out to PlanetCNC Support they are a great bunch of people who would love to help you get going.
    The USBCNC is in many ways a better controller, just need them to guide you through the settings a bit. Refer to OpenBuilds ACRO System -> Scroll down to Machine Settings - that would help too (use the names to find equivalent values in PlanetCNC settings. Keep posting here and we'll help you where you get stuck, just include screenshots etc
    If you send them the Grbl settings from the ACRO page they might be able to help better too
    #14 Peter Van Der Walt, Mar 18, 2019
    MaryD likes this.
  15. Fa.Steinhauser
    I try it, thank you !
  16. Peter Van Der Walt
    Seeing as you are building an awesome, custom machine (not just a acro as a laser) the MK3/4 is going to be awesome by they way - its more expandable to custom things like these than a Grbl board would be. Just chat to their support and their forum, while we do resell their boards, the support is done over on their forums and chat - they do an awesome job.
  17. Fa.Steinhauser
    Yes i try !! ……... to build this Maschine......but now it is growing over me .
    I worked yesterday Hours throu the menue fron planet cnc….now ist working …..
    The next Problem is , i am searching a simply Software to generate simply g Code files .
    I only Need simply Things done, like two straigth lines or a circle .
    Everything in 2d …..
    The tool commands are the Problem ...i dont have found out how it works in g Code to turn on the pwm Signal and turn off .
    Ist my first Project with a x-y Portal , thats the Problem …..
    But i have to do it ….. ist a very important exam for me and i cant repeat it...
  18. Peter Van Der Walt
    So did a little checking for you:
    if you have the PlanetCNC setup as above.
    Then refer to LaserWeb/LaserWeb4 and set
    TOOL ON COMMAND = M3
    TOOL OFF COMMAND = M5
    PWM MAX S VALUE = 255
    GCODE START:
    G21 ;mm mode
    G90 ;absolute positioning
    GCODE END:
    M5
    M2
    That should get you lasering
  19. Peter Van Der Walt
    PS: LaserWeb and OpenBuilds CAM won't do straight lines. Both need closed vectors (a closed vector has at least three points. A line has 1)
    but you can also hand-write gcode: LinuxCNC "G-Code" Quick Reference
    G0 X?? Y?? to position where to start
    M3 to turn on
    G1 X?? Y?? to move to end of line
    M5 to turn off
    Michiglenn likes this.
  20. Fa.Steinhauser
    Hey Peter !!
    Thank You very much , that helps a lot !!!!!
    Wish you a gerat Day!
